Light behind clock burnt out
Old Dec 21, 2004 | 02:39 AM
'00Accordster's Avatar
Default Light behind clock burnt out
The light that illuminates the clock on my 2000 accord LX sedan is burnt out. Im talking about the the one that illuminates when you turn on your headlights. How do i replace it, where would i get it from, and how much would it cost??
I performed a search and came up with nothing.
Thanks in advance
Old Dec 21, 2004 | 10:46 AM
Turbowa's Avatar
Default Re: Light behind clock burnt out ('00Accordster)
You can buy it from any honda dealer. Its around $5-6. You will need a small flat head screw driver to pry the clock assy out of the dash and you will see it on the side of the clock assy.
Old Dec 21, 2004 | 01:06 PM
Heat's Avatar
Default Re: Light behind clock burnt out (Turbowa)
Just a side note, to pop the clock off in a way that minimizes the chance of damaging your dash, put some masking tape on the dash under the clock, then wrap your flathead screwdriver in a thin piece of cloth. Pry up from the bottom (the bottom of the screwdriver will be against the masking tape). There'll be some clips, once they are free the clock assembly will slide towards you.
Old Dec 22, 2004 | 11:54 AM
Jerminator's Avatar
Default Re: Light behind clock burnt out (Heat)
I have this problem, but it's the AC light with all the AC controls that is out. Does anybody know if it's removable similar to the clock talked about here?
Thanks
Old Dec 22, 2004 | 02:21 PM
Heat's Avatar
Default Re: Light behind clock burnt out (Jerminator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jerminator &raquo;</TD></TR><TR><TD CLASS="quote">I have this problem, but it's the AC light with all the AC controls that is out. Does anybody know if it's removable similar to the clock talked about here?
Thanks</TD></TR></TABLE>What year is your Accord? On my '99, there's just one light for the AC (when you press in the button). I'm not sure how to remove the button, though my light for my cruise control button is also burned out (but I just ignore it since my cruise is always on, it doesn't engage until I press the button on the steering wheel).
Old Dec 22, 2004 | 05:45 PM
98carbonaccord's Avatar
are all your dashlights out too? if so, you need a new multiplexor
the bulbs above the AC button are leds, the bulb that lights up the AC button is a regular bulb i believe.
tmryan
Apr 26, 2018 03:01 PM
Randy4000
Apr 8, 2015 08:00 AM
sky9
Apr 7, 2011 03:41 PM
nick25
Jun 22, 2005 07:47 PM
