Integra shifter work in crx wit hasport B series shift linkage?
Old Dec 20, 2004 | 10:52 PM
tRex99's Avatar
Default Integra shifter work in crx wit hasport B series shift linkage?
Well heres the deal i have a 90 integra in the garage i just got with a B&M short shifter and i have a 91 crx si with a jdm B16 with the hasport shift linkage. Now does the 90 integra shifter fit in that linkage? i couldnt member what ones i used in my ls swap. Also cant member is those linkages are just shortened crx linkages or shortened integras... will it work?
Old Dec 20, 2004 | 11:01 PM
BuCKxWiLD's Avatar
Default Re: Integra shifter work in crx wit hasport B series shift linkage? (tRex99)
i'm pretty sure 90-93 integra shifters are interchangeble with crx shifters, they might have a different angle out into the cabin though but the bottom bolt to the linkage should be the same
Old Dec 20, 2004 | 11:19 PM
tRex99's Avatar
Default Re: Integra shifter work in crx wit hasport B series shift linkage? (BuCKxWiLD)
oh thats ok on the angles cause this stock B16 shifter is hitting my plastic interior so its a pain to get it in first...this other shifter has some mean *** bends in it
Old Dec 21, 2004 | 12:02 AM
WhiteDSM520's Avatar
I have a DC shifter in my car. I had to modify it slightly but it feels way better, its working with my hasport linkage. There's a tube that a bolt slides through on the shifter and pivots on. That tube needs to be cut down a tiny bit w/ a dremel. It's a 15 minute job if you have the linkage to make sure you cut it down right.
fortillian
Apr 3, 2011 08:35 PM
suno
Oct 11, 2008 10:44 PM
crxsleeper210
Aug 27, 2006 10:51 AM
xDicktonesx
13
Aug 11, 2005 01:55 PM
ricodemus
Jul 24, 2002 07:52 AM
