need 88 crx hf info
Old Dec 20, 2004 | 10:23 PM
Wilson_'s Avatar
Default need 88 crx hf info
i just bought a 88 crx hf and i noticed the rear lower control arms are diffrent from other civics(i used to have a 95 ex coupe and a 00 si)
can i use the lower control arms off other year civics?
TIA
Old Dec 20, 2004 | 11:23 PM
BuCKxWiLD's Avatar
Default Re: need 88 crx hf info (Silverstone00Si)
you could probably use LCAs from 88-91 civics which are probably what you are use to seeing.. also the 89-91 crx's are like the 95 coupe's and 00 si's, but the 88 crx LCAs are like Type-R LCA's which = dope!! hehe
Old Dec 21, 2004 | 06:00 AM
89crxhf's Avatar
Default Re: need 88 crx hf info (BuCKxWiLD)
88 crx's had a passive rear steering on them
Old Dec 21, 2004 | 08:57 AM
Tyson's Avatar
Default Re: need 88 crx hf info (89crxhf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89crxhf &raquo;</TD></TR><TR><TD CLASS="quote">88 crx's had a passive rear steering on them
that has nothing to do with the the difference in the rear control arm.
ALL crx's had passive rear steering. 88s just had a bit more dialed in by a different geometry in the chassis mounting of the front toe link.
you just need to know the 88's require special ordering of rear shocks due to the difference in design.
Tyson
18
Mar 31, 2019 12:23 AM
Skipper75
Suspension & Brakes
Apr 20, 2007 07:54 AM
Eee Pee
Nov 1, 2003 10:21 PM
Soon2BeEK
15
Jun 15, 2003 01:17 PM
