00-01 GSR exhaust OEM
Can this(00-01 GSR exhaust) bolt on to 94+ LS/RS/GS integras?
What is the diameter of this pipe? is it the same as the GS/LS/RS?
Is the tip the same as the LS/RS/GS?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuraLSSE95 »</TD></TR><TR><TD CLASS="quote">Can this(00-01 GSR exhaust) bolt on to 94+ LS/RS/GS integras?
Is the tip the same as the LS/RS/GS?</TD></TR></TABLE>
Seeing as the A-pipes are the same, I believe the diameter and length of the exhaust is the same. However I don't know about the tip, I think they are the same. The only difference is the muffler, I think.
Edit: I'm not an expert, so if someone can validate any of my claims that would be great.
Yes, the length and hanger location for the 94-01 LS/GS/RS/SE exhaust is the same as the 00-01 GSR. The piping size is the same on the OEM system, the only difference is that the tip is shaped slightly differently on the newer integras (99-01? or so). The tip got slightly pointy, while the older integras had your usual round tip design.
