Weight of Omni Power Coilovers
Old Dec 20, 2004 | 08:02 PM
Tony the Tiger's Avatar
Default Weight of Omni Power Coilovers
I did a good detailed search and found pretty much all the info I needed on the Omni coilovers, except for one thing -- the weight of these coilovers. I posted the same topic on the Civic forums, but I assume there aren't many Civic owners with them.
Anyone ever put these coilovers (each) on a scale?
Old Dec 20, 2004 | 09:45 PM
c_rogue69's Avatar
how about you email the company and have them tell you?
Old Dec 20, 2004 | 09:58 PM
Default Re: (c_rogue69)
Already did... still waiting for a reply
Old Dec 22, 2004 | 12:07 AM
B18OnTop's Avatar
Default Re: (Tony the Tiger)
Would like to know as well.
Old Dec 22, 2004 | 01:20 AM
RicharDC4's Avatar
Default Re: Weight of Omni Power Coilovers (Tony the Tiger)
aww, if you asked this question about a week ago i could have answered. but too bad, now the omnipowers are already on the car.
Old Dec 22, 2004 | 09:28 AM
Dc2 David's Avatar
try to IM omniman himself
Old Jan 31, 2005 | 07:42 PM
Default Re: (GSR david)
I purchased a set of Omni Coilovers and weighed them myself
Fronts are 9.5 lb each
Rears are 9.0 lb each
Much more lighter than stock! My Koni/Eibachs were 20 lbs for the fronts and about 17 lb for the rears.
Old Jan 31, 2005 | 07:48 PM
hondandy's Avatar
I think he means the spring rate, I'll try to find this list of spring rates I have.
Old Jan 31, 2005 | 07:51 PM
Racermech's Avatar
What is omni website?? I keep searching and keep comming up with sites that sell the stuff, but i want to find there's
Old Jan 31, 2005 | 08:03 PM
Default Re: Weight of Omni Power Coilovers (Racermech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">What is omni website?? I keep searching and keep comming up with sites that sell the stuff, but i want to find there's</TD></TR></TABLE>
http://www.omnipowerusa.com
Old Jan 31, 2005 | 08:05 PM
Default Re: (hondandy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondandy &raquo;</TD></TR><TR><TD CLASS="quote">I think he means the spring rate, I'll try to find this list of spring rates I have.</TD></TR></TABLE>
The above numbers I've posted is the physical weight of the coilover units. You wouldn't believe there was approximately 30 lb weight savings just by switching to these coilovers, including the fact that I am getting a better suspension setup at the same time
For spring rates, they are:
Spring rates are 10 kg/mm front and 8 kg/mm rear for the STREETS
Spring rates are 12 kg/mm front and 10 kg/mm rear for the SPORTS
kornerk12
Oct 28, 2006 05:29 PM
blkgsr03
Suspension & Brakes
Jun 22, 2006 03:06 PM
Tony the Tiger
Dec 20, 2004 07:05 PM
