the never ending taillight drama
Old Dec 20, 2004 | 12:51 PM
CRX Si's Avatar
Default the never ending taillight drama
Ok I searched, Tried some stuff I found but am still coming up short... I have a 90 Crx si, The tailights, parking lights, and cluster lights are not working... The fuse didnt blow... I checked the bulbs and they are all fine... Im thinking ground... Does anyone know where this cercuit grounds to? It did this before and It was the rear defogger switch, I unplugged it and It was fine... Any other suggestions?
Old Dec 20, 2004 | 01:03 PM
Outsane's Avatar
Default Re: the never ending taillight drama (CRX Si)
there are little clear boxs with 5 or so wires going to them..
those are the light grounds.. try them...they are near the headlights on the fender side.
Old Dec 20, 2004 | 01:13 PM
CRX Si's Avatar
Default Re: the never ending taillight drama (Outsane)
awsome, thanks man, ill check it out...
Old Dec 20, 2004 | 02:03 PM
CRX Si's Avatar
grounds looked ok but ill have to check better when I can see better... Any other ideas to amuse me?
Old Dec 20, 2004 | 02:37 PM
wompwomp61's Avatar
there might be exposed wires somewhere. try to follow them as best as possible. these are old cars
Old Dec 20, 2004 | 02:42 PM
SETI20's Avatar
I had the same issue, and I had a fried wire on the back of my fuse box.
That's the one under the dash.
Old Dec 20, 2004 | 04:27 PM
doublethink's Avatar
if your sure its not fuse related, did it happen one day out of the blue, or was it after you did some mod/work to the car?
if after you worked on the car make sure all the grounds are on, if not then you have a short (break in the wire) between the fuse box, and the devices that arent working.
at that point your options would be to find a patient mechanic whos going to fix it the right way and not ghetto it, or buy the electrcial troubleshooting helms and find it yourself, mine just came in the mail today
http://www.helminc.com/helm/Re...A149E
one more thing, sometimes fuses that are labeled for one thing also affect another, check them all, and the ones under the hood before you really move onto other things.
good luck.
Old Dec 21, 2004 | 09:09 AM
CRX Si's Avatar
Default Re: the never ending taillight drama (doublethink)
yeah it was out of the blue... I parked at royal farms and walked out and started the car and no lights... im getting fed up with my car...
Old Dec 22, 2004 | 03:42 PM
CRX Si's Avatar
well the lights are back at the expense of my climate control... any one have a spare 90-91 crx Si climate control laying around?
lilsicsoul
Mar 14, 2009 02:30 PM
queda
May 23, 2008 08:42 AM
i hate rice
11
Aug 22, 2006 05:26 PM
eyegiant
Honda Civic (2001 - 2005)
11
Jun 7, 2006 03:09 PM
DropSquadCivic
Sep 11, 2003 10:00 PM
