Portflow inner valve springs
Old Dec 20, 2004 | 11:51 AM
ITRFreddy's Avatar
Default Portflow inner valve springs
If I use just change out the inner valve spring on my R to Portflows, and use Toda B's; will that be enough security to avoid any valve float or anything else damaging to the engine? What would be my max RPM with these inner springs?
Old Dec 20, 2004 | 02:09 PM
RagingAngel's Avatar
Default Re: Portflow inner valve springs (ITRFreddy)
https://honda-tech.com/zerothread?id=71600
search.... you might get a lot of that here...... good luck.....
Old Dec 20, 2004 | 08:45 PM
GUILOTINE's Avatar
Kill Gil
If your using your stock ITR Exhaust outer valve springs (blues), the maximum lift they can handle is 11.5mm, any more and they will coil bind. If you up grade your exhaust outer valve springs to the stock ITR intake (Yellow) you can handle up to 12.5mm lift all around. HTH
Old Dec 20, 2004 | 10:34 PM
KayOs's Avatar
From what I understand, spec B and spec C TODA camshafts require TODA valve springs.
ITR outer/inner valvesprings may be used up to 8400 RPM.
janiscrulzz
K Series
Nov 13, 2016 09:03 AM
90teg
Aug 2, 2005 08:10 AM
nsx-Animal
Sep 24, 2001 08:18 PM
