No Reverse lights??
I searched and found a few threads..none that were REALLY helpful.
Recently i just noticed that my reverse lights aren't working.. I checked the bulbs and swapped them out and no dice.
I'm starting to lean towards my reverse light switch..but i'm not 100% sure
Are there any fuses that control the reverse lights?
Not sure about the fuses but you can check the switch on the tranny.. Just hook a continuity meter up to the switch and it should be connected when in reverse.. Also check to make sure one of the wires for the reverse switch didnt come off..
Did you put the car in reverse while the key is in the on position and then test the wires/ socket with a test light? See if your getting power first before you start pulling everything apart.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">Did you put the car in reverse while the key is in the on position and then test the wires/ socket with a test light? See if your getting power first before you start pulling everything apart.</TD></TR></TABLE>
Will do.. thanks for your reply
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">Not sure about the fuses but you can check the switch on the tranny.. Just hook a continuity meter up to the switch and it should be connected when in reverse.. Also check to make sure one of the wires for the reverse switch didnt come off..</TD></TR></TABLE>
I will look to see if one of the wires came out..
I'm out of school right now so i don't have access to a meter because the shop is closed.
Anything else i could try?
Thanks guys
Thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C00SI »</TD></TR><TR><TD CLASS="quote">There should be two wires under the dizzy that have connectors on them plug em in .
Ill get some pix if you dont figure it out by tonight.</TD></TR></TABLE>
Yeah if you could get some pics..
Thanks In advance
Thanks In advance
JDMJUNKIEMONKIE
Oct 25, 2009 02:17 AM
headingnorth
Oct 13, 2007 08:26 PM
