89 crx door panels NEED TO KNOW ASAP
they should with the exception of the passive seat belt problem
older CRXs had the seat belts on the b-pillar (not on the door) and the newer ones had "passive restraints" (aka on the door)
That's the only issue you'll run into, otherwise if they match they'll fit
I believe starting in 1989 they began manufacturing the passive seat belt doors for the CRX. So you should be OK, and they should match the 91's... but try and get a pic of them first.
661rex89si
Oct 2, 2006 02:43 PM
