jeep wont start in cold weather
Old Dec 20, 2004 | 09:04 AM
GSR-T-'s Avatar
Default jeep wont start in cold weather
My 94 jeep wrangler(beater) is having trouble staring up in the cold weather. The colder it is the longer it takes to start. I sit there for about 30 seconds cranking it and then it starts right up.
Old Dec 20, 2004 | 09:05 AM
GSR-T-'s Avatar
another thing is that the check engine light will pop up 2 seconds before its about to start(then shuts of after its started)??... thanks for any help you guys can provide
Old Dec 20, 2004 | 09:28 AM
mmuller's Avatar
Mad Scientist
Default Re: (GSR-T-)
Ohhhhh, sell your pos jeep and buy another honda
since hONdA is BeTtA ThAN All----- j/k
http://www.jeepforum.com/forum/index.php
http://www.4x4wire.com/forums/...=&C=5
you might want to ask in a dedicated jeep forum
Old Dec 20, 2004 | 10:23 AM
GSR-T-'s Avatar
haha... i do have a honda.. this is just the beater. fun as **** too and parts are cheap too and cops dont look twice..
Old Dec 29, 2004 | 09:15 AM
GSR-T-'s Avatar
haha thanks for all the help...
just put in brand new battery didnt help
Old Dec 29, 2004 | 12:57 PM
GSR-T-'s Avatar
Old Dec 29, 2004 | 02:09 PM
AbitAvenger's Avatar
bump because it looks pimp sitting next to the R
Old Dec 29, 2004 | 04:18 PM
TeStUdO's Avatar
Try adding the treatment to take water out of fuel lines. I had to use it alot when i was in north dakota.
Old Jan 11, 2005 | 07:00 AM
GSR-T-'s Avatar
yeah, Ill try that... any other suggestions?
Old Jan 11, 2005 | 07:10 AM
civicross's Avatar
Thinner oil?
What weight are you using? How fast does it turn over?
Old Jan 11, 2005 | 10:43 AM
GSR-T-'s Avatar
Im using the regular 10w 30... and the turn over time all depends on the temperature.. (Example:Warm day = starts up within 5 seconds of cranking and cold day = 30-60 seconds of cranking)
Old Jan 11, 2005 | 11:00 AM
AL ASPIRATED's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR-T- &raquo;</TD></TR><TR><TD CLASS="quote">haha thanks for all the help...
just put in brand new battery didnt help</TD></TR></TABLE>
what is the CCA rating on the battery?
Old Jan 11, 2005 | 12:54 PM
GSR-T-'s Avatar
I have no idea.. what does CCA stand for? Ill have to check after work.. its from walmart thats all i know.. haha
Old Jan 11, 2005 | 08:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR-T- &raquo;</TD></TR><TR><TD CLASS="quote">I have no idea.. what does CCA stand for? Ill have to check after work.. its from walmart thats all i know.. haha</TD></TR></TABLE>
CCA=Cold Cranking Amps
How much amps the battery can provide at 0degrees temp.
the higher the CCA rating, the less likely you will have problems starting your car in cold weather
Old Jan 12, 2005 | 05:51 AM
GSR-T-'s Avatar
ok i just looked on the battery and is says 540 cold cranking amps and 640 reg. or max cranking amps??.......
Old Jan 12, 2005 | 12:11 PM
GSR-T-'s Avatar
Old Jan 12, 2005 | 07:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR-T- &raquo;</TD></TR><TR><TD CLASS="quote">ok i just looked on the battery and is says 540 cold cranking amps and 640 reg. or max cranking amps??.......</TD></TR></TABLE>
540 is pretty low, espicially your in the cold weather. imma check at work to see what your OEM CCA rating is at.
Old Jan 13, 2005 | 07:09 AM
GSR-T-'s Avatar
alright thanks
Old Jan 13, 2005 | 12:12 PM
GSR-T-'s Avatar
up.. sometimes it starts right up really weak at first and sometimes it doesnt even try and start at all....
Old Jan 13, 2005 | 03:37 PM
00000xxx's Avatar
i had a jeep for awhile, they always take a long time to start, average warm weather startup is 8 sec's.
Old Jan 19, 2005 | 08:09 AM
GSR-T-'s Avatar
so what about the winter time?.. just didnt start..ha
Old Jan 19, 2005 | 09:42 AM
supercreed2002's Avatar
I got 850 CCA at 0 degrees in my 92 honda and it fires right up!!
Caleb
Old Jan 25, 2005 | 05:54 AM
GSR-T-'s Avatar
any other ideas people..
Old Jan 25, 2005 | 07:20 AM
SearchBeforeUPost!'s Avatar
You need to find out what code it is throwing. I work at a jeep dealer, let me know what they are
could be crank sensor
Old Jan 25, 2005 | 09:23 AM
GSR-T-'s Avatar
.. okay now we are getting somewhere... the check engine light doesnt stay on though??... it comes on just as its about to start
