How hard is it to install the AEM CAI?
Old Jan 4, 2002 | 10:17 PM
GSRacer2102's Avatar
Default How hard is it to install the AEM CAI?
I made up my mind and went with the AEM CAI and I am going to get it tommorrow. I was reading in the Lude forum and they were saying that it was extremly difficult to put it on the Lude. So I just wanna know how hard it is to install on a GSR
Old Jan 4, 2002 | 10:29 PM
BagelW's Avatar
Default Re: How hard is it to install the AEM CAI? (GSRacer2102)
Putting the AEM in is the easy part. Taking the stock air box out is a pain. Overall though, it's a pretty simple install.
Old Jan 4, 2002 | 10:35 PM
Wildohiorice's Avatar
New User
Default Re: How hard is it to install the AEM CAI? (bagelw)
Exactly
Old Jan 4, 2002 | 10:50 PM
ingrate's Avatar
25 Year Member
Default Re: How hard is it to install the AEM CAI? (Wildohiorice)
it's a lot easier than installing it on a prelude
Old Jan 4, 2002 | 11:08 PM
StinkyTofu's Avatar
Exactly
he sure said it. for installation guide take a look at this one. it worked for me. http://members.tripod.com/mintydip/
Old Jan 5, 2002 | 01:31 AM
GSRaCeRbOI's Avatar
Default Re: How hard is it to install the AEM CAI? (B-18C1)
installation of the AEM is really easy on the GSR
no hardcore dremel work n stuff if thats what your thinking from the prelude..
[Modified by GSRaCeRbOI, 10:36 AM 1/5/2002]
Old Jan 5, 2002 | 01:32 AM
OneThirtyEight's Avatar
Very, Very easy.
Old Jan 5, 2002 | 08:44 AM
Neo's Avatar
Neo
also, once installed make sure you check the clearances of the CAI around the A/C tubing by the coolant overflow tank and back where the intake goes in a downward direction before it does the 90 degree right bend toward in intake manifold. Before I learned about the AEM CAI "rub" problem I had rubbed through all of the insulation and started rubbing throught the SS A/C tubing by the intake mani Good luck!
Old Jan 5, 2002 | 08:46 AM
1fastGSR's Avatar
New User
very easy
Old Jan 5, 2002 | 08:56 AM
Neo's Avatar
Neo
Default Re: How hard is it to install the AEM CAI? (Titus333)
The installation is easy, taking off the bumper is easy
Good God Almighty -- you do not, I repeat you DO NOT, have to remove the front bumper to install the AEM CAI. All you have to do is jack up the front passenger side of the car and remove 2 or 3 small bolts that hold the splash guards in place to gain access to where the K&N filter get attached to the end of the intake. Taking off the bumper is doing it the hard way...
Old Jan 5, 2002 | 09:55 AM
MachAF's Avatar
Default Re: How hard is it to install the AEM CAI? (Neo)
Its pretty easy. Only hard part for me was putting the vaccum hoses on there the coolant goes the the intake manifold. ( I got coolant every where )
Stock air box is the hardest part to get out. One bolt it up in the tire well, which I had to bend back the entire slashguard thingy.
Its pretty easy though.
dLo GSR-stolen-now-WRX
Jun 18, 2005 04:51 PM
kAME
Oct 5, 2004 05:58 PM
TrueZen
Oct 31, 2003 12:40 PM
nickdoe
Jun 11, 2003 08:36 AM
Ohlias
Mar 5, 2002 08:53 AM
