FS: Chicago, IL HF manifod, DSM SMIC's, 2 t3 turbos, t25, hks manifold, gsr seats, b16a shortblock,
Old Dec 20, 2004 | 01:48 AM
Akiraboy's Avatar
Default FS: Chicago, IL HF manifod, DSM SMIC's, 2 t3 turbos, t25, hks manifold, gsr seats, b16a shortblock,
OK as you can see I have alotta stuff for sale. I have too many projects & I need to make room. No matter, if you are local c'mon over & make a killin. Heres your chance for a shot at my private collection. Save yourself the cost of shipping. Lotta boost junk- d series ninjas REKOGNYZE
pics & prices to follow:
1. 1st up for sale, 3 1g DSM sidemount intercoolers, combine with the turbos & HF manifolds I have in this same thread & you can have 1 EZ KILLA setup without havin to visit junkyard after junkyard...knuckle bustin in the FREEZIN COLD $35 each NO LONGER AVAILABLE
2.90 Grand Prix gtp turbo front mount intercooler, same as the SMIC if not better, factory black finish, people will not see this from behind the bumper $25
3. Miscellaneous boost pipes, mix n match $5 ea NO LONGER AVAILABLE
4. Short ram intake pipe with hks style mushroom filter. Underneath the duct tape is a polished aluminum pipe. Combine with the boost pipe above & rig up a low buck cold air or ? Strange as it sounds the duct tape deflected 15 deg F of underhood heat...fyi $15 pipe $ 10 for Filter & frame, or $ 20 for both NO LONGER AVAILABLE
5. 1 T25 turbo off of a 90 Grand Prix GTP turbo. GREAT TURBO. Minimal shaft play, no in-n-out shaft play, O2 is aok, use with the HKS log style manifold I have pictured below or combine with the b16a shortblock I have for sale & you'll have 1 fun sleepa , $100 NO LONGER AVAILABLE
6. d series hks style cast iron log manifold. $150. NO LONGER AVAILABLE
pics of the T25 and the HKS style manifold together [perfect match HINT HINT]
7. 2 hf, cx, vx manifolds. D series all the way I wanna say that these were off a eg cx or vx. Not cracked or damaged. Combine this with the T3 adapter plate and T3 turbo I have further down & all you'll need is a downpipe & BANG you're boostin your D series
$35 for the covered one $30 uncovered NO LONGER AVAILABLE
the cover is another stealth gotta-have-it item for a starter ninja
8. [kinda blurry] BMC raceplates T3 turbo adapter. This is a new unused adapter plate. The key to any junkyard turbo project. It will allow you to bolt your HF manifold to your T3 for instant turbo pleasure . Sam sells em for 50+ unshipped, $ 40 picked up SOLD Junkyard racer
9. If any of this is making sense to you yet you'll see that the bmc race plate I had pictured above is bolted to this t3 turbo and as you can already guess this turbo is for sale. T3 of a Saab not a bad spooler for a d, but better for a b16, b18 or ? Junkyard turbo love. $50 sold to wojo - on H-T
10. another t3 turbo, this time off of a running Volvo. It was in a black turbo 4dr I was going to buy from the junkyard. I lowballed em & they junked it
Doesn't matter, all I wanted was the turbo , same as the description above:
Slight shaft play, no in-n-out, turbine wheel does not rub. Spins freely. $50
11. Greddy blue box, 92-95 EX or SI sohc of course. $20
SOLD to lazyassbrian good buyer
decent fuel management for your soon-to-be turbo setup
12. 88-91 spare d16a6 head from 89[Si ?]. I bought this as a spare to rebuild if I blew up my d16a6, in case my turbo hiccuped. NEVER HAPPENED! so I don't need it. Not warped or crapped out. Send it out to port & polish while you drive your car without any down time. Or slap it on in place of a blown head and go. The car I got it off of had 90-96k miles on it. $40 SOLD to dvious hatchie
13. D16y8 sohc vtec stock camshaft, I swapped this out for a crane cam last year. nothing is wrong with it, don't need it. $10
14. d series underdrive crank pulley, $10 sold Mikeyspec
15. 2 D series cable trannys.
1 Si tranny broken 1-2 shifter fork $50
sold final drive & countershaft to dvious hatchie
1 ZC dohc tranny[no lsd]$100 Sold to Mikeyspec
Si tranny needs only a shifter fork, goto any junkyard & pocket it freebie
Zc transmission needs nothing, install it & bang close ratio row-boatin @ its best
Now combine the ZC 3rd & 4th gear along with the SI final drive 1st second and 5th & you have I killer *** D series cable tranny track proven to shave .7 tenths in the 1/4th mile NA with no other supporting mods. Doubt it? Search Mista bone on honda-tech & see what he's done on this setup & NOS. this is a smokin setup for boost. Some consider it too close but look at how close the gear ratios are on the type r tranny & think about it. Not to say this is the same but if you use shorter tires, ect.
16. type r shift ****, unused $5
17. short throw shifter SOLD to Splitime good buyer
18. Flywheel, clutch and pressure plate for the ZC DOHC all 3 are in great shape: FREE with ZC tranny purchase NO LONGER AVAILABLE
19. EF 88-91 Auto to manual cable conversion $20 in da garbage
combine with the short shifter & all this other crap I'm sellin cmon you gotta love it
20. lightweight Miata wheels all 4 $200 NO LONGER AVAILABLE
rumored to weigh a scant 10lbs, I weighed them @ 11lbs but DAMN these are light, can you say DRAG wheels??? Straight & clean, judge for yourself. Free HP
21. B16a shortblock alternator included on it, as pictured $150
Sold to Mikeyspec for less than 150
[psst, this one is a great combo with that t25 up there ]
22. gsr cams $30
23. ZC intermediate shaft $40 Sold
24. b16a flywheel, appears fine,freewith b16a purchase
25. gsr seats $80 for both no rips or tears, firm padding. drivers seat has lumbar
grey color SOLD to JDMBSIXTEEN, good buyer
26. ISHI rhb5 turbo off of a Subaru, spins freely, minor/minimal shaft play,
NO in-n-out or wheel rub. I am currently running rhb5 turbo on my wagon as we speak, spools great. Perfect for the d series ninja starter. You will not be disappointed $60 Sold to d15dx___
Reason I'm sellin all my stuff you ask?
Need room , I have a 97 GSX I need to complete before Feb. & I need to park my turbo wagon in my garage & keep it outta the bitter cold. Can't do both with my parts collection.
As with all the above mentioned items c'mon by & check it out.
Don't go lowball crazee, I'd rather keep it & build another EF but I want this stuff gone, otherwise I'll ebay it
Giving the locals 1st dibs.
Modified by Akiraboy at 9:54 PM 6/5/2005
Modified by Akiraboy at 10:19 PM 11/6/2006
Old Dec 20, 2004 | 06:11 AM
junkyard racer's Avatar
Default Re: FS: Chicago, IL HF manifod, DSM SMIC's, 2 t3 turbos, t25, hks manifold, gsr seats, b16a shortblo
dibs on a t3, smic, and maybe the hf manifold/adaptor plate.
pm'd.
Old Dec 20, 2004 | 08:56 AM
Akiraboy's Avatar
pm replied,dunno bout that time frame, I'll try if anything is left
its on the Chicago thread now
Old Dec 20, 2004 | 03:41 PM
Akiraboy's Avatar
minus 1 short shifter, bump for the update.
Old Dec 20, 2004 | 04:04 PM
CLERIC's Avatar
I'll take the blue box off your hands. Let me know.
Old Dec 21, 2004 | 03:07 AM
88redrex's Avatar
hey bump for chicago! Interested in a T3- about 25 mins outta downtown email me- rexbro2@yahoo.com
Old Dec 21, 2004 | 04:49 AM
Akiraboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CLERIC &raquo;</TD></TR><TR><TD CLASS="quote">I'll take the blue box off your hands. Let me know.</TD></TR></TABLE>
local sale pending on the blue box, everything else is still up. Cmon by & pick it up
Old Dec 21, 2004 | 08:13 AM
s1ngle's Avatar
bump for quality cheap junkyard turbo stuff, but i'm too poor
Old Dec 21, 2004 | 10:53 AM
Akiraboy's Avatar
thanks for the bump, if stuff doesn't start sellin then I'll start droppin prices like wal-mart, remember i prefer LOCAL PICKUPS H-T peeps
Old Dec 21, 2004 | 10:55 AM
Akiraboy's Avatar
everything is still up
Old Dec 21, 2004 | 11:17 AM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Bumped for viewing
Old Dec 21, 2004 | 06:34 PM
Akiraboy's Avatar
shortshifter sold to Splitime
GSR seats sold to jdmbsixteen
everything is still up 4 sale, cmon Chi town high rollers
whez dem benjaminzzz
Old Dec 21, 2004 | 09:37 PM
88redrex's Avatar
Chicago Bump- $35 for a t3 picked up? PM me
Old Dec 21, 2004 | 10:06 PM
Akiraboy's Avatar
never hurts to try
Old Dec 22, 2004 | 08:44 PM
Akiraboy's Avatar
nuther cold nite, up again 4 the nite owls
Old Dec 23, 2004 | 07:29 AM
INVALID's Avatar
Still pending on the Greddy BB or is it gone?
Old Dec 23, 2004 | 08:14 AM
Akiraboy's Avatar
sold to lazyassbrian @ 10:30 am approx. sorry.... but PM brian: according to him, he may using it as a temporary fix prior to going to uberdata or ?
Old Dec 24, 2004 | 05:52 AM
Laserjock's Avatar
I'll take these two for $260 shipped to 22192. What payement can you accept. I can paypal by tonight!
Old Dec 24, 2004 | 08:00 AM
Akiraboy's Avatar
Update: zc, intermediate shaft, underdrive pulley and b16 sold
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Laserjock &raquo;</TD></TR><TR><TD CLASS="quote">5. 1 T25 turbo off of a 90 Grand Prix GTP turbo. GREAT TURBO. Minimal shaft play, no in-n-out shaft play, O2 is aok, use with the HKS log style manifold I have pictured below or combine with the b16a shortblock I have for sale & you'll have 1 fun sleepa , $100
I'll take these two for $260 shipped to 22192. What payement can you accept. I can paypal by tonight!</TD></TR></TABLE>
sorry sale pending to junkyard racer
Old Dec 25, 2004 | 09:00 AM
Laserjock's Avatar
okledokle
if the sale doesn't happen give me a heads up-
Old Dec 25, 2004 | 10:40 AM
Akiraboy's Avatar
10-4
Old Dec 27, 2004 | 02:58 PM
Skank_aSS_Dara's Avatar
check pm
Old Dec 27, 2004 | 06:19 PM
Akiraboy's Avatar
pm replied
Old Dec 27, 2004 | 07:06 PM
Laserjock's Avatar
sent you a pm too. pick me! pick me!
Old Dec 31, 2004 | 04:34 PM
bump for a great guy! i just met him and picked up a few things. really a good guy.
i defentally vouch for this guy!
thanks again frank.
