Price on an item
ya you would be better off just getting a new clutch, pressure plate etc. you may as well since the tranny would be out, also you would be better doing it yourself it is not very hard to do at all
Depends on if the clutch is old or not. If the clutch has very low miles then no need to change. If the clutch is high milage then replace it and don't forget to turn the flywheel!!!!!!!!!!!1
