MPFI gone worng!!!!
Old Dec 19, 2004 | 07:51 PM
crxbust's Avatar
Default MPFI gone worng!!!!
just turnd my dpfi in to mpfi and not getting any spark, new distributor and all is connected right and useing LS ECU help .............
Old Dec 19, 2004 | 08:04 PM
c for sea's Avatar
Default Re: MPFI gone worng!!!! (crxbust)
you damn ricer.
Old Dec 19, 2004 | 08:07 PM
PHOBIA's Avatar
Default Re: MPFI gone worng!!!! (c for sea)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c for sea &raquo;</TD></TR><TR><TD CLASS="quote">you damn ricer. </TD></TR></TABLE>what a worth less piece of **** reply c for sea.just tell him to use the search function like every one else and give the basics. check wiring first.
Old Dec 19, 2004 | 08:08 PM
Civic138's Avatar
your using a DOHC ecu for a SOHC motor?
if so,what the hell are you thinkin
Old Dec 19, 2004 | 08:11 PM
PHOBIA's Avatar
Default Re: MPFI gone worng!!!! (Civic138)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic138 &raquo;</TD></TR><TR><TD CLASS="quote">your using a DOHC ecu for a SOHC motor?
if so,what the hell are you thinkin</TD></TR></TABLE>ah christ i didnt even see that part
Old Dec 19, 2004 | 08:16 PM
c for sea's Avatar
Default Re: MPFI gone worng!!!! (PHOBIA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHOBIA &raquo;</TD></TR><TR><TD CLASS="quote">what a worth less piece of **** reply c for sea.just tell him to use the search function like every one else and give the basics. check wiring first.</TD></TR></TABLE>
chill bro. he's a dude i know.
but anyway. double check the wiring. the most common problem i've seen for no spark are the two white distributor wires.
Old Dec 19, 2004 | 08:48 PM
sohczchf's Avatar
switch the two white wires arround on the dizzy
also a pr4 ecu will work on a sohc i'm running one in mine it works great
also are you using a si dizzy or ls dizzy if you are still using dx wont fire
Old Dec 19, 2004 | 08:54 PM
c for sea's Avatar
he's got a brand new Si dizzy
Old Dec 19, 2004 | 10:50 PM
PHOBIA's Avatar
allright man thats cool just looking out for people is all.no harm done
xparalandrax
18
Feb 8, 2008 10:39 PM
ej2civic
Jun 18, 2007 07:32 AM
migizzel
15
Feb 23, 2006 01:13 PM
streetracerjoey210
Oct 30, 2005 12:25 PM
MM's94Civic
Jun 25, 2004 09:42 PM
