Please HELP! Need Advice Quick!
hello guys,
i recently put an h22 in my accord. my egr on the h22 is bad and so is my tp sensor i think. will the tp and the egr work off of my accord motor f22. the egr looks exactly alike, but the have different codes on the side. my car is idling rough in the morning, once it warms up its good. i have thrown a TP code once and never seen again. is this the tp? please help thanks
shane
shane
If you want to see if any of the parts are interchangeable check out this website. You can compare most of them by part number to see it they are the same or not.
http://www.hondaautomotivepart...y.jsp
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forcedaccord95 »</TD></TR><TR><TD CLASS="quote">the egr looks exactly alike, but the have different codes on the side.</TD></TR></TABLE>
He already said the codes (part numbers) are different.
Jack *** (forcedaccord95) part of the EGR control device is the same on both engines. He also didn't mention if the part numbers on the TP sensor were different so I gave the link to check them.
Modified by SpeedFreak77 at 7:49 AM 12/21/2004
