search wont work.. will the 12000k HID's melt the integra light housing
Old Dec 19, 2004 | 05:45 PM
mikestypeRR's Avatar
Default search wont work.. will the 12000k HID's melt the integra light housing
??????? will the 12000k HID's melt the integra light housing??????????????
if so what is the highest rated HID the integra housing can handle?
Old Dec 19, 2004 | 05:53 PM
Dan GSR's Avatar
Default Re: search wont work.. will the 12000k HID's melt the integra light housing (mikestypeRR)
? the kelvin rating is for color ??
that being said 12,000 k will probably be darker than OEM halogen
Old Dec 19, 2004 | 05:56 PM
KayOs's Avatar
HID's draw less amperage than halogen. Therefore I don't think you will have a problem with any housing melting.
kelvin rating and light output have an indirect relationship. The higher the kelvin rating, the lower the emitted light will be. Stick with your halogen bulbs if that's your intention.
Default Re: search wont work.. will the 12000k HID's melt the integra light housing (Dan GSR)
well the 12000k is a bluish purple color .... looks really hot.. but i also know that there is a heat rating scale anyone know what the heat rating for the housing are.
Old Dec 19, 2004 | 05:58 PM
Default Re: search wont work.. will the 12000k HID's melt the integra light housing (KayOs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KayOs &raquo;</TD></TR><TR><TD CLASS="quote">HID's draw less amperage than halogen. Therefore I don't think you will have a problem with any housing melting.
kelvin rating and light output have an indirect relationship. The higher the kelvin rating, the lower emitted light will be. Stick with your halogen bulbs if that's your intention.</TD></TR></TABLE>
well the hid's actually improve visibility darastically... so i like to see were i am going.
anyways any help would be cool thanks.
Old Dec 19, 2004 | 05:59 PM
p nut's Avatar
Though I have not seen it in person, 12k is supposed to be a lot darker than 4500 or 6000. I'm personally going with 6000k, which is supposed to have a bluish look. 4500k (white) is supposed to illuminate the best.
Old Dec 19, 2004 | 06:00 PM
KayOs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikestypeRR &raquo;</TD></TR><TR><TD CLASS="quote">
anyways any help would be cool thanks.</TD></TR></TABLE>
Not with HID's rated at 12000K. You will get less light output than your halogen bulbs. Color may be all there, but you won't be able to see s**t.
Old Dec 19, 2004 | 06:03 PM
Azcheron's Avatar
12k is wayyyyyyyy tooo darkkk
my buddy has 10k and its rediculously blue
my other friend has 6k and even that is pretty blue
12k is nutty, you will get pulled over, but to each his own
plus really crappy light output
6k
8k
10k
12k
Old Dec 19, 2004 | 06:06 PM
Dan GSR's Avatar
4300-4500 will have the brightest light
I have personall seen 6,000k and 8,000 k
6,000 was a good looking blue'ish color, but less light output
8,000 was pure ****** purple, and had very poor light ouput
I can't even imagine 12,000k
my reccomendation, get OEM bulbs 4,300-4,500
Old Dec 19, 2004 | 06:11 PM
RTW DC2R's Avatar
stunners!
Old Dec 19, 2004 | 06:12 PM
Tweakmeister's Avatar
I've got 7k and it looks ******y purple
let this be a lesson to all
Old Dec 19, 2004 | 06:15 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: search wont work.. will the 12000k HID's melt the integra light housing (Tweakmeister)
no it won't melt
as long as you have room between hid bulb and the plastic lenses, you should be fine
Old Dec 19, 2004 | 06:16 PM
p nut's Avatar
Any of you guys get these HID kits?
https://honda-tech.com/zerothread?id=1050083
Looks like it's a good product, but just wanted to know if any of you have tried it. I'll probably go with the 5600k
Old Dec 19, 2004 | 06:18 PM
Money Hou$e's Avatar
As others have said stick w/4300-4500K, if you want a blue light get some neons.
Old Dec 19, 2004 | 06:30 PM
Dan GSR's Avatar
Default Re: search wont work.. will the 12000k HID's melt the integra light housing (mltdown)
BMW retrofit owns all
the little bit of glare I have is because my car is white, and the light is reflecting off my bumper
Old Dec 19, 2004 | 06:50 PM
uNF$@#!'s Avatar
guys, remember V = IR from physics? it actually, works.
V = voltage (e.g. 35 watts,)
I = current (amps)
R = resistance (ohms)
since in the system the resistance remains the same, voltage and current have a directly relational proportion. voltage goes down, so does the current used.
Old Dec 19, 2004 | 07:19 PM
Chris F's Avatar
Default Re: search wont work.. will the 12000k HID's melt the integra light housing (255.255.255.255)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 &raquo;</TD></TR><TR><TD CLASS="quote">V = voltage (e.g. 35 watts,)
Voltage is measured in volts. Power in watts. P=IV.
Old Dec 19, 2004 | 08:31 PM
Bbasso's Avatar
there is no noticeable heat difference between ratings on HIDs for cars, the 4300 or 6000 up to your insanely blue rating of 12000 is for color rating.
...How could you, that's so uncool
Old Dec 19, 2004 | 08:34 PM
uNF$@#!'s Avatar
Default Re: search wont work.. will the 12000k HID's melt the integra light housing (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
Voltage is measured in volts. Power in watts. P=IV. </TD></TR></TABLE>
BAN! GTFO!
you actually made me wonder about how i wired up a few led's...
luckily i used the V=IR formula (12 v)
Old Dec 19, 2004 | 08:43 PM
Big Teggie's Avatar
Dont even waste your time 12000k HID's.
I would rather drive with my lights off before using a set of 12000k.
Old Dec 19, 2004 | 11:29 PM
cryptikman's Avatar
Default Re: search wont work.. will the 12000k HID's melt the integra light housing (Big Teggie)
12k, are you kidding? Might as well stick candles into your headlamps.
Old Dec 20, 2004 | 12:03 AM
.water's Avatar
Default Re: search wont work.. will the 12000k HID's melt the integra light housing (cryptikman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cryptikman &raquo;</TD></TR><TR><TD CLASS="quote">12k, are you kidding? Might as well stick candles into your headlamps.</TD></TR></TABLE>]
hahahaha..that will melt your light housing for sure. and it will got out about 10mins or so..lol
Old Dec 20, 2004 | 12:07 AM
MissMyHonda's Avatar
Stop being a ricer and get some 4300 or 6K if you want a little tint to them...the higher # does NOT mean more light
Old Dec 20, 2004 | 06:30 AM
DragII's Avatar
25 Year Member
Default Re: (JoesTypeS)
anything over 8k
Old Dec 20, 2004 | 06:33 AM
thk's Avatar
thk
Members Only
Default Re: (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">stunners!</TD></TR></TABLE>
