Help:BRAKE light is on
Old Jan 4, 2002 | 08:09 PM
stRtypR25's Avatar
Default Help:BRAKE light is on
if you guys could please help me......my brake light is on......has this ever happened to anyone....if so what is the prob?thanx for the help in advance
when i put my e-brake down....the light still stays on...plz help
Old Jan 4, 2002 | 08:14 PM
DR. ON POINT's Avatar
Banned
Default Re: Help:BRAKE light is on (stRtypR25)
check all ur bulbs....u probably put in a 1158 instead of a 1157 in ur brake lights
bus stop's Avatar
First thing I will do is check the brake fuild level......
Old Jan 4, 2002 | 08:51 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Like they said, check the brake fluid level and make sure your bulbs work. If it's still f'd up, we'll look at it at the dyno day if you come.
Old Jan 4, 2002 | 09:14 PM
GRM Scott's Avatar
25 Year Member
I think he's talking about the BRAKE light that comes on when you pull up the parking brake. Maybe the trigger that the parking brake activates is stuck? take your center console off (very easy, just 4 screws on the side) and see if there's anything uncool in there). Here's a stupid question...is that the same light that comes on if there's a brake problem?
Old Jan 4, 2002 | 09:29 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: Help:BRAKE light is on (Aleph)
I had this problem - my e-brake light came on while I was on track! scary ****...turned out the cover to my brake fluid reservoir wasnt on tight enough. I tightened it, and it went off.
Old Jan 4, 2002 | 09:50 PM
b00st-0wnz's Avatar
Yes, same light. Indicates a bad bulb, low fluid, etc.
Old Jan 5, 2002 | 08:37 AM
stRtypR25's Avatar
yea its the BRAKE light that goes off when you put the e-brake down....whats weird is that ill be driving and the light will be on and then after a couple of minutes it goes off
Old Jan 5, 2002 | 08:38 AM
yoshi234's Avatar
I shoot brides
it's either the brake fluid level or loose cap, as mentioned above.
Old Jan 5, 2002 | 09:17 AM
stRtypR25's Avatar
Default Re: Help:BRAKE light is on (yoshi234)
thanx guys for all the help i really appreciate it
Bruce Banner
Nov 30, 2010 08:44 AM
cfran55
Sep 9, 2008 06:13 AM
sonson6
Apr 8, 2007 05:58 PM
Pullig
Aug 30, 2005 11:51 AM
zerogravitycrx
Apr 6, 2005 11:29 PM
