Do i need the beaks kit?
Old Dec 19, 2004 | 05:21 PM
intougera's Avatar
Default Do i need the beaks kit?
hey guys i just installed a 22mm usdm itr swaybar on my 96LS. i've heard that without a beaks or bsq subframe reinforcement kit the sway bar will rip the bolts right out of the subframe. what are the chances of that? let me know if you have the kit, general knowledge, whatever. thanks
Old Dec 19, 2004 | 05:42 PM
lak8's Avatar
Default Re: Do i need the beaks kit? (intougera)
I jsut ordered a itr 22mm rear sway bar for my integra from the dealer.
You need the kit sence the non type-r models integra's dont have a flat rear subframe needed for the 22mm bar, thats why a plate (bsq/beaks) is put in place which gives it extra strength and the support needed. (just to much force on the frame with the bigger type-r bar) If money is a factor, the bsq kit is the cheapest in price but i hear it can rub on the abs lines so some ppl go for the beaks. (you can correct this buy adding some washers tho to the bsq kit i hear) or you could always make your own.
Hope that helps
Old Dec 19, 2004 | 06:09 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Do i need the beaks kit? (lak8)
Yes, you need it. I had a smaller 21mm bar with no reinforcement and it ripped my subframe. Either kit will work great. I've helped install both.
It's a little bit of insurance for a high price to pay if you rip the subframe.
Old Dec 19, 2004 | 07:30 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You also need a kit so that the bar will mount closer (directly) to the subframe. This keeps the bar from exerting too much torque on the subframe and ripping the bolts out. The stock brackets that mount the stock bar away from the frame will definitely cause tearout if you use them to mount an ITR bar.
Old Dec 19, 2004 | 07:32 PM
Vtecfool's Avatar
Default Re: Do i need the beaks kit? (PatrickGSR94)
i highly recommend it! Beaks Great quality..
Old Dec 19, 2004 | 10:38 PM
Mattyg2's Avatar
why not just buy sway bars that are made for your car, like comptech or something?
Old Dec 19, 2004 | 10:46 PM
importdude2000's Avatar
Default Re: (Mattyg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mattyg2 &raquo;</TD></TR><TR><TD CLASS="quote">why not just buy sway bars that are made for your car, like comptech or something?</TD></TR></TABLE>
cheaper
Old Dec 20, 2004 | 02:22 AM
SlipAngleX's Avatar
yea since you said you already installed it, make sure you dont take corners to hard. Get the reinforcements first before you go out to have fun.
You can always make your own by just adding the correct size washers. (my set up consists of multiple washers and works well, its been on for 3 years)
Old Dec 20, 2004 | 04:54 AM
Community Builder
Because the bars made for our cars pretty much mount the same way as adding a reinforcement kit to an ITR bar.
My friend put ST bars on his Civic DX, which didn't come w/ swaybars stock, and the rear bar bushing brackets came with a plate and a spacer, EXACTLY like the BSQ kit.
odogg726
Feb 21, 2007 09:22 PM
Maxboost808
Jun 16, 2004 02:01 PM
chethewitt
Nov 5, 2002 12:16 AM
StinkyTofu
Jul 16, 2002 06:00 AM
ITR00-816
Aug 28, 2001 12:22 PM
