Compression Test on Stock B16A
Old Dec 19, 2004 | 04:12 PM
gamakichi77's Avatar
Default Compression Test on Stock B16A
i'm running an B16A on my EK......ECU P30, Stock head and bottome ends, just an CTR cams on it......
i would like to know what range is the value for my compression test?
Old Dec 19, 2004 | 07:46 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Compression Test on Stock B16A (acidburns_di)
Around 180PSI
Old Dec 19, 2004 | 07:54 PM
mmuller's Avatar
Mad Scientist
Default Re: Compression Test on Stock B16A (LSVTEC 91 Civic)
just do the test and see what you get, if #'s are even across the board your good.
Asking for the compression #'s is really not a lot since you have variables like tester, temp., altitude.
Old Dec 21, 2004 | 02:47 AM
anothersickhatch's Avatar
i would think it would be a little higher than 180psi. like muller said, as long as the numbers are within 10-15 psi of eachother then you should be ok.
i would guess more like 200-210, but if your numbers dont turn out that high but are still similar, then i wouldnt worry about it. its still gonna have power.
Old Dec 22, 2004 | 06:43 PM
Default Re: Compression Test on Stock B16A (anothersickhatch)
thanks
Old Dec 22, 2004 | 06:56 PM
Lord Helmet's Avatar
as long as it doesn't go below 135 PSI you'll be fine. anything below that factory specs requires as rebuild.
b16a971
Feb 20, 2016 11:46 PM
B16A Hatchback
Aug 22, 2008 09:25 PM
laocivic
Jan 9, 2008 09:21 AM
celestialcivic91
Jan 23, 2007 03:12 PM
TylerH
Mar 15, 2006 11:16 AM
