Did a search, didnt find enough info, just wondering..................
Old Jan 4, 2002 | 06:16 PM
Boughetto's Avatar
New User
Default Did a search, didnt find enough info, just wondering..................
I am startingt o find interest in the hatches you guys drive. Especially the white one's w/black rims, and vice versa. What is the most common engine swap for this car? And what engine's can go in? here is what I'm thinking can work.
h22a
GSR
si
type r
also, the 1/4 times?
Old Jan 4, 2002 | 06:17 PM
FifthGearOnline's Avatar
Default Re: Did a search, didnt find enough info, just wondering.................. (blue95accord)
i would say that the most common are the B16A, and the B18C-1
Old Jan 4, 2002 | 06:18 PM
DragII's Avatar
25 Year Member
all will fit...H22 being the hardest...most common would be a GSR motor B18c1
if you can afford it...you can get a type R B18c5, if you can't consider a SI B16a, or LS B18b.
cheers!
Old Jan 4, 2002 | 06:19 PM
icyballa3's Avatar
the gsr (b18c1), the new si (b16a(3?)) and the type R(teg type r and civic type R)(b18c5 and b16b) all drop right in (i think) the h22 is out of a prelude and it takes a lot more work 2 put in, is a lot heavier and will not let you keep ps or ac. Also the type Rs are much more expensive as is the h22. Also, which hatch are you looking at?
[Modified by icyballa3, 3:20 AM 1/5/2002]
Old Jan 4, 2002 | 06:29 PM
jonas's Avatar
Default Re: Did a search, didnt find enough info, just wondering.................. (icyballa3)
b16a2 = 99-00 si.
Old Jan 4, 2002 | 06:30 PM
-Gambit-'s Avatar
i would think that the b16 (si motor) would be the most common swap because its the cheapest and easiest
Old Jan 5, 2002 | 07:44 AM
Boughetto's Avatar
New User
Default Re: Did a search, didnt find enough info, just wondering.................. (ek9hatch)
Thanks guys! Ya, I figured it was ther GSR/SI motor. Ya, if I did end up doing hybrid, I could not afford a Type-R engine. GSR seems nice. Thanks again
andrius7
K Series
Dec 31, 2016 07:58 AM
dirtyharryhatch
Jul 2, 2008 02:11 PM
manwezy951
Apr 26, 2005 03:38 PM
91bluehatch
Mar 15, 2005 06:56 AM
h22 civ
Apr 4, 2003 03:56 PM
