2002 cr 125 problem
Old Dec 19, 2004 | 08:05 AM
civichbb18's Avatar
Default 2002 cr 125 problem
i have a 2002 cr125 and in first gear when you floor it the bike bogs out even when its warm the plug looks good it not running to rich or to lean the air filter is clean whats up ryan
Old Dec 19, 2004 | 09:46 AM
jdmp's Avatar
Default Re: 2002 cr 125 problem (civichbb18)
could be a problem with the carb. If you get on it slightly does it go...only does it when you open it up real quick???
Old Dec 19, 2004 | 11:21 AM
Ag-Eng's Avatar
Default Re: 2002 cr 125 problem (jdmp)
Sounds like a carb or reed problem.
Take it in to a mechanic (not the stealership)
Old Dec 20, 2004 | 02:20 PM
jdmp's Avatar
Default Re: 2002 cr 125 problem (Ag-Eng)
try using some carb cleaner and if that doesnt work i suggest the above
