**Gauge cluster with TACH**
Old Dec 18, 2004 | 04:58 PM
fast90hatch's Avatar
Default **Gauge cluster with TACH**
I am looking for a new gauge Cluster for my 1990 Civic DX. i want to put in a cluster with a tach in it. i wanted to know what is the best cluster that will fit in with the most easy.
Thanks
Old Dec 18, 2004 | 05:08 PM
PaImportTuner's Avatar
Default Re: **Gauge cluster with TACH** (fast90hatch)
90-91 crx or civic si cluster should be an automatic swap. Some DXs have the wire/plug right behind the cluster if some case it was swapped out. If not ur going to either have to run a line from the ECU or Distributor to that cluster or aftermarket tach.
if you use GSR i think you need to get a VSS and change wiring.
Old Dec 18, 2004 | 06:15 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: **Gauge cluster with TACH** (PaImportTuner)
just find an 90-91 cluster with a tach, it will plug right in. i have an 88-89 for sale, but you would have to re-pin the plugs which is kind of a bitch for a downgrade cluster.
Old Dec 18, 2004 | 06:17 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PaImportTuner &raquo;</TD></TR><TR><TD CLASS="quote">
if you use GSR i think you need to get a VSS and change wiring. </TD></TR></TABLE>
yes, that is correct, this is the cluster i swapped out my stock one for...i still havent gotten vss hooked up, havent had time to do it...it was fairly easy to redo wiring, just time consuming
Old Dec 19, 2004 | 07:03 AM
Default Re: **Gauge cluster with TACH** (b2o-vtec)
what about a SIR gauge cluster... I have seen them on ebay. But i have to get a USDM one cuz of teh stupid MPH issue. But will they go right in??
Old Dec 19, 2004 | 07:23 AM
mr_valentino20032000's Avatar
get the EDM one. It has a higher redline on the tac and also goes to 150 if i remember right. Oh and its mph
Swe NitraM
12
Jan 21, 2012 04:17 PM
V.MoMO
Sep 12, 2010 08:44 AM
sikefcrx89
Nov 16, 2009 04:13 PM
triple5soul8781
Aug 7, 2008 05:46 AM
89DXDann
Jun 4, 2004 11:38 PM
