Got to use the new welder today!!
Old Dec 18, 2004 | 03:56 PM
TurboJesse
Guest
Posts: n/a
Default Got to use the new welder today!!
Well i purchased A Hobart Tigmate from B18c1cya a few weeks ago and finally got some time to weld on it This is my second attempt @ trying to weld a collector and i must say it came out better than the first time (thanks Full-race Geoff )...It still could use alot more work but its 100x better than my first.
Old Dec 18, 2004 | 04:09 PM
B18C1CYA's Avatar
Default Re: Got to use the new welder today!! (Mpir3)
its good to see you where able to finally use it just keep at it they will get better , and you will weld them faster also , looks good
Old Dec 18, 2004 | 04:37 PM
Canuk_SiR's Avatar
now all you need is a better camera!
Old Dec 18, 2004 | 04:39 PM
TurboJesse
Guest
Posts: n/a
Default Re: Got to use the new welder today!! (Canuk_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Canuk_SiR &raquo;</TD></TR><TR><TD CLASS="quote">now all you need is a better camera! </TD></TR></TABLE>
its my mom's...i gotta pimp her out so she can afford a new one
Old Dec 18, 2004 | 10:54 PM
untitled's Avatar
Looks good!
But you wanna make the collector at the lowest angle possible. Hence the name "low-angle merge" collector. You want to provide the lowest angle possible for the collector so it will flow better. So i recommend using 5inch collector pipes unless you have to use the length that you have used for fitment reasons.
TIG is all about practice. Remember no to pulse the pedal tryin to emulate the 1/2 moon looks. That will come with torch time.
Good luck!
CRXTION
Jan 7, 2011 01:54 PM
rdt
Sep 30, 2006 05:26 PM
pacifico
May 30, 2005 10:14 AM
second edition
Jan 17, 2005 02:10 PM
skafia
Jun 26, 2003 05:59 PM
