Hydro trans in-place of cable trans.
I have a b18c in a crx with a j1 cable tranny.
if i were to purchase a hydro trans, what would be needed to swap it in place.
Things im wondering...
Shift linkages, same different?
Axles, same different?
Rear mount, same different?
How it physically bolts to the engine mount. Do they have a different mount pattern? Because im using welded in 91 LS mounts and they work great for cable, but do the hydro trannys use the same mount.
As for the hydro part, i would just rig something up. Just want to make sure where the mount bolts to the tranny its the same as on the cable ones.
Thanks.
Thanks.
I have a hydro trans in my crx. Im pretty sure the mount would be diff. I know hasport offers 2 diff kits. axles should be the same. Just buy the kit I wouldnt chance riggin it. Heres a pic where you can see the adapter.
All you need to know is in this post: https://honda-tech.com/zerothread?id=650859
Einhander276
16
Feb 9, 2011 02:03 PM
jnagel12006
Sep 21, 2008 02:14 PM
