Na setup on b18c1..hows it sound?
Old Dec 18, 2004 | 03:01 PM
B18cHatch06's Avatar
Default Na setup on b18c1..hows it sound?
ive got a hatch with a b18c1 with just i/h/e..i plan on building it within a few months just searching to see if what i want sounds just about right for being street drivin n on the weekends have a lil fun..well heres what i want to do with it..
s2s2 or blox s2 cams with springs/retainers
the best header i can keep a/c with i need help on this guys!!
ctr .25 over pistons to bump my compression
blox IM
arp head studs
block guard n some other things to make it a stronger motor
with a hondata s100 or s200 system..trying to decide
help me out!!
Old Dec 19, 2004 | 10:38 AM
chameleon's Avatar
Default Re: Na setup on b18c1..hows it sound? (B18cHatch06)
your on the right track, there are tons of simlilar setups in the all motor section which show dyno #s and track times to prove how strong they can be so def search so you can see other people's accomplishments as far as recommendations..
P30 pistons to yield around 11.7-9 comp
blox IM since its better than skunk2
and go with blox cams they are identical to skunk just cheaper
s100 system is just cleaner and simpler
and on the header is a tuff one but look into smsp or along the lines..
Old Dec 19, 2004 | 11:02 AM
Default Re: Na setup on b18c1..hows it sound? (chameleon)
yea..now my only problem is to find out which header would be best for me to KEEP a/c..anyone have an opinion let me know..money isnt a problem
Old Dec 19, 2004 | 11:15 AM
1999all_motoR_teg's Avatar
If money isn't a problem then I would suggest a Hytech Header I have one and have a/c. Search to see if SMSP let's you keep the a/c as that is another great choice.
Bserieskllr
28
Jan 5, 2005 05:09 AM
adro2333
22
Jun 18, 2004 10:38 AM
Infamous
10
Jan 21, 2004 12:17 AM
snake01
Sep 7, 2003 06:58 PM
Combustion Contraption
17
Aug 29, 2003 06:50 PM
