d16y8 intake (EGR equipped) on a D16z6 head?
Old Jan 4, 2002 | 03:24 PM
eg6ajk's Avatar
Default d16y8 intake (EGR equipped) on a D16z6 head?
I got a D16Y8, to fit on my D16z6 head....anyone know how to fix the little problems I have...
1)one is the EGR valve (i think it, can be just plugged up without a problem),
also what gasket to use D16y8?
2)next I can't find the IAT (intake air temp. sensor), anyone knows, where it is located on the 96+ cars or how I can fix this to work? there is no provisions or a sensor?
3)next is the IAC valve, which I think should just work fine, the stock d16y8?
anyone else did this?
Old Jan 4, 2002 | 04:46 PM
speedillusion's Avatar
New User
Default Re: d16y8 intake (EGR equipped) on a D16z6 head? (eg6ajk)
is the ex intake manifold compatible with a dx? i'm trying to swap the throttle valve, and the manifold, off an ex into a dx. what else would i need?
Old Jan 5, 2002 | 04:17 AM
eg6ajk's Avatar
Default Re: d16y8 intake (midnitekreeper)
yes, it will bolt up to any d-series (other then ZC DOHC)....
anyone who did a d16y8 onto EG? how did you resolver the IAT problem?
H-adict
Feb 4, 2007 07:31 PM
hondacivic4g
Jun 24, 2002 10:43 PM
