Are 13 second 1/4 mile times possible with these mods?
Old Jan 4, 2002 | 03:23 PM
typer694's Avatar
New User
Default Are 13 second 1/4 mile times possible with these mods?
So far my best 1/4 mile time is a 14.4@98mph with the following mods(this is at over 4000 feet above sea level and 90 octane gas, the highest available here)
AEM intake, DC 4-2-1 1 piece header, DC cat back, AEM adj cam gears, B&M fuel pressure regulator, UR crank pully, TODA flywheel, ACT street strip disc / HD pressure plate, JDM final Drive, C's short shifter, spoon 1.35 bar radiator cap.
I am going to replace the DC header with a JDM ITR header and install a car sound cat and apexi N1 cat back. Also going to install a set of TODA Spec A cams and TODA cam gears. Do you think this will get me into the 13's at this elevation?
Old Jan 4, 2002 | 03:28 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Are 13 second 1/4 mile times possible with these mods? (typer694)
you should already be running 13s - go to sealevel and find out I forget the formula for converting elevation to times and stuff, but maybe someone else knows
StinkyTofu's Avatar
i think its possible...it'll be hard though. I don't think toda spec A cams are much better then your stock ones though. If you tune your car on the dyno, things will look much better for you
Old Jan 4, 2002 | 03:30 PM
TurboITR's Avatar
Default Re: Are 13 second 1/4 mile times possible with these mods? (B-18C1)
90 octane - **** i would have tapped out already if that were the case here...
more power too ya
Old Jan 4, 2002 | 03:38 PM
Incognito's Avatar
Default Re: Are 13 second 1/4 mile times possible with these mods? (TurboITR)
Get spec B's. I have a setup similar to that and I run 12.9's
Old Jan 4, 2002 | 05:24 PM
typer694's Avatar
New User
TurboITR, yeah it sucks! I am origanly from MD, i miss good ole SUNOCO 94! Hell i miss alot of things, MIR, E-town, damn i need to move back to the east coast. But untill then i am stuck with 90.
Old Jan 4, 2002 | 05:57 PM
SpeedRacer00-667's Avatar
you should hit 13' no problem
GOOD LUCK
Old Jan 4, 2002 | 07:33 PM
Type R's Avatar
Default Re: Are 13 second 1/4 mile times possible with these mods? (Incognito)
hmmmm whats your setup???
Old Jan 5, 2002 | 07:52 PM
Incognito's Avatar
Default Re: Are 13 second 1/4 mile times possible with these mods? (Type R)
AEM cam gears
AEM CAI
Holley FPR
OBD 1 ECU w/Skunk2 program and jumper
Portflow retainers + inner valve springs
Toda spec B cams
MSD wires
Apex VAFC
Spoon header (had JDM 4-1)
Clutchmasters stage 3 clutch
13" Lenso's with 22x8x13" slicks
Ran open exhaust (I have the Apex N1 though)
Old Jan 5, 2002 | 08:03 PM
Batoutahell's Avatar
Just curious, how much whp do you make with your car?
Old Jan 5, 2002 | 11:13 PM
Incognito's Avatar
Default Re: Are 13 second 1/4 mile times possible with these mods? (Batoutahell)
A hair under 200.
Will dyno again within a few weeks.
I'll post up the graphs.
Old Jan 5, 2002 | 11:59 PM
Type R's Avatar
damn nice setup/time
some graphs would be dope
Jul 9, 2002 04:55 PM
ITR#97-0039
Jul 8, 2002 04:12 PM
nsx-Animal
Dec 11, 2001 11:59 AM
ak-s2000
Nov 21, 2001 02:03 PM
TypeR 1159
Aug 23, 2001 02:07 PM
