Just found some useless info, DONT FOLLOW "MUST SEE"
Old Dec 18, 2004 | 11:20 AM
Spoogen_1's Avatar
Default Just found some useless info, DONT FOLLOW "MUST SEE"
Ok i was looking around and came across this
http://www.team-integra.net/se...D=732
it shows you how to rewire your hood release so people cant get in easy from outside.
now i know how to still get in and this info doesnt do anything. Look at how they do it. and it doesnt solve anything. To open the hood relese, all you have to do is stick your hand up the front grill and find the release wire, and pull it. thats all you have to do, and it takes two senconds, so please dont listen the that thread.
Old Dec 18, 2004 | 11:42 AM
Lewie's Avatar
I'm here for the gangbang!
Default Re: Just found some useless info, DONT FOLLOW "MUST SEE" (Nexus131)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nexus131 &raquo;</TD></TR><TR><TD CLASS="quote">Ok i was looking around and came across this
now i know how to still get in and this info doesnt do anything. Look at how they do it. and it doesnt solve anything. To open the hood relese, all you have to do is stick your hand up the front grill and find the release wire, and pull it. thats all you have to do, and it takes two senconds, so please dont listen the that thread.</TD></TR></TABLE>
What? Link doesn't work, your english sucks, and this has already been covered in previous threads.
Answer to all your problems
Here's a link to the article you're referring to: Hood latch relocation
This is quite effective, maybe you should read the entire article. Many people have done this successfully.
Old Dec 18, 2004 | 11:45 AM
tony4311's Avatar
It's called layers. The more the better. It's common for recovered Integras to have the wheel wells cut out for access. If it's not there they wasted time and they've been slowed down. The longer it takes the better. If you don't think every layer helps you're an being dumb.
Old Dec 18, 2004 | 12:25 PM
Calsonic's Avatar
I have razor blades underneath my front bumper near the area of the hood release cable (which has been re-routed). I also have a hood sensor on my alarm and modified battery terminals and secondary battery power source along with countless other security mods.
Old Dec 18, 2004 | 04:31 PM
tub_sephiroth's Avatar
Thanks. I didn't know that. I will give it a try when my car is out of storage.
Old Dec 18, 2004 | 04:47 PM
AlxSiR7's Avatar
why is that a bad idea? just as long as a lot of people dont see you opening your hood like that then it's fine... i have a sensor on my hood to that will go off when its opened. when someone breaks in and tries to pull the hood latch they will most likey just leave because they are in a hurry and assume the latch is just broken..
Old Dec 18, 2004 | 04:49 PM
tony4311's Avatar
Default Re: Just found some useless info, DONT FOLLOW "MUST SEE" (AlxSiR7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlxSiR7 &raquo;</TD></TR><TR><TD CLASS="quote">why is that a bad idea? just as long as a lot of people dont see you opening your hood like that then it's fine... i have a sensor on my hood to that will go off when its opened. when someone breaks in and tries to pull the hood latch they will most likey just leave because they are in a hurry and assume the latch is just broken..</TD></TR></TABLE>
The hood still works the same way.
Old Dec 18, 2004 | 04:59 PM
PredatorGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">why is that a bad idea? just as long as a lot of people dont see you opening your hood like that then it's fine... i have a sensor on my hood to that will go off when its opened. when someone breaks in and tries to pull the hood latch they will most likey just leave because they are in a hurry and assume the latch is just broken</TD></TR></TABLE>
The DIY just pushes the cable out of the way and attaches in inside of the engine bay so that you can't reach it from the wheel well. No wires are permanently disconnected or anything.
Old Dec 18, 2004 | 05:08 PM
dc2legend's Avatar
IQ &gt; you
I don't know about you but it would be a lot harder going through the grill than just ripping out some plastic.
Old Dec 18, 2004 | 09:19 PM
calxtreme's Avatar
Default Re: Just found some useless info, DONT FOLLOW "MUST SEE" (Calsonic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Calsonic &raquo;</TD></TR><TR><TD CLASS="quote">I have razor blades underneath my front bumper near the area of the hood release cable (which has been re-routed). I also have a hood sensor on my alarm and modified battery terminals and secondary battery power source along with countless other security mods.</TD></TR></TABLE>
Man, some crazy stuff about the razors in the bumpers. May I have a little more information about the "modified battery terminals?
Old Dec 20, 2004 | 12:36 AM
Calsonic's Avatar
Default Re: Just found some useless info, DONT FOLLOW "MUST SEE" (calxtreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calxtreme &raquo;</TD></TR><TR><TD CLASS="quote">Man, some crazy stuff about the razors in the bumpers. May I have a little more information about the "modified battery terminals?</TD></TR></TABLE>
I don't want to say too much since thieves read this message board. Basically, positive & negative are reversed and there is a metal bracket around the terminal that can't be taken off without hex tools. There is a way for thieves to disconnect a stock battery without popping the hood (yes, that is pretty scary to know). That's why I had to modify it.
Old Dec 20, 2004 | 01:44 AM
calxtreme's Avatar
Hmm....definately interesting. And yes, that is scary. I don't know how it would be done, but man, if these thieves put their effort into something good, think of all the good thing that can be achieved. Haha. So much ingenuity for crime.
Old Dec 20, 2004 | 02:33 AM
yeegsr's Avatar
YOU ARE useless dude...they did not stated that the rewiring the hood cable WILL stop theft from getting into ur car. They said "it would reduced the chance"
by the way if you actually do that ****....you will come up with solution that people can't put their hand from the front bumper to pull the hood's cable....there is a way that u can't pull from front...so stfu about useless or not
they give u the idea and solution u must do it urself and do it better...better than sitting ur *** on ur chair and talking ****...i think u just give out the infomation of how to pull the cable for more people to know and so more car will get stolen...
at least they tried....
Old Dec 20, 2004 | 03:40 PM
calxtreme's Avatar
I'm sure he now realizes that he made a mistake by posting what he did. Don't be so hard on the guy.
Old Dec 20, 2004 | 06:07 PM
HARI.'s Avatar
damn, this guy must be a theif. he's probably just mad because it will be harder for him to pop hoods once everyone relocates their cables
HighRevn
71
Jun 28, 2006 08:53 AM
Froznface
Feb 3, 2006 06:11 AM
Mr. JDM-GSR
Jan 9, 2006 11:47 AM
A-busive
29
Jun 3, 2005 01:46 PM
GSR-T-
Jul 9, 2003 08:52 AM
