front brakes are integra....how do i upgrade rear?
Check this out.....i have 90 LS Integra disk brakes uo front..... i want rear disks as well..... i know i can swap out for 91 Si CRX but what parts do i need and are they expensive.......would http://www.majestichonda.com be the place to buy this from? Is the Si conversion the only conversion? I have already looked into http://www.fastbrakes.com and i want to keep the front the same size (integra) and they only make 11in conversions! Thats overkill dont you think? anyways help me out guys..... 1989 Honda CRX HF
Engine:B16 JDM Sir
Transmission:JDM YS1
ILOVE THIS SITE
Engine:B16 JDM Sir
ILOVE THIS SITE
I have the rear trailing arms and disc brakes from a 90-93 integra.
I unbolted the ebrake lines and rear trailing arms and swapped the integra's in, easy as that. Search for more info.
are you serious?! thats freakin awesome..... ima go do the conversion right now! my friend and i got in a car accident and his 91 LS is wrecked! Im going to ask him for his brakes...... thats all you need?
I hear you must shorten the parking brake cable if you use integra rear brakes. How are you guys doing this?
Use the crx control arms (compensator, upper and lower control arms). The integra compensator arms are longer. Using them will create a toe in problem. The integra lower control arms are straight and the civic lcas are offset. That will twist the inner bushing in the lca.
Reverend
Sep 18, 2001 03:25 PM
