accord 01 brake warning light pops on . When it is cold outside
Old Dec 18, 2004 | 08:55 AM
mrma8328's Avatar
Default accord 01 brake warning light pops on . When it is cold outside
I have an 01 accord v6 coupe with 104000 miles on it ..lately The brake warning light is on when I either first start the car or when I am braking it disappears after a couple of hours and alot of driving.. Last time this happen the dealer replaced the sensor. is it the same thing again the canister is full of fulid and i don't notice any leaks and the brakes work fine
Old Jan 28, 2005 | 10:21 AM
1badmk1rocco's Avatar
Default Re: accord 01 brake warning light pops on . When it is cold outside (mrma8328)
Same $hit happens on my 01 Accord. What's the deal? I don't know much about Hondas except they don't brake very often.
Old Jan 28, 2005 | 10:25 AM
philadd's Avatar
Default Re: accord 01 brake warning light pops on . When it is cold outside (1badmk1rocco)
Take the cap off the brake fluid resevoir... you should see two electrical connections. Clean off those connections and you should be fine. I did this for my friend's Accord, and she hasn't had that problem since.
Old Jan 28, 2005 | 11:18 AM
hondadude's Avatar
Check the Brake Fluid level the reason it happens cold is because fluid contracts when cold, remember basic science class in grade school?
If you are low on fluid it could be because the front brake pads are worn out, the front calipers you a large volume of fluid. Also look at the brake booster under the master cylinder, if the master is leaking it will show at that place.
Old Jan 28, 2005 | 12:40 PM
philadd's Avatar
Default Re: accord 01 brake warning light pops on . When it is cold outside (hondadude)
He already said that the brake fluid level was fine. It's not going to drop from the full mark all the way down to the low mark just because it's cold. And frankly, I've already dealt with this exact problem. There's no need to be condescending.
Again, just clean off those 2 connections thoroughly and you shouldn't have this problem again.
Old Jan 30, 2005 | 10:38 PM
Default Re: accord 01 brake warning light pops on . When it is cold outside (philadd)
Flushed the system, cleaned the contacts, we'll see what happens next time the Temp drops
adamcm16
Apr 10, 2014 05:07 PM
todmunpla
Oct 31, 2010 08:30 PM
goobernoodles
Mar 30, 2009 08:27 AM
Jaysun
May 15, 2007 04:36 AM
kcb203
Mar 8, 2006 11:27 AM
