ZC Swap into a CRX HF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yomomz »</TD></TR><TR><TD CLASS="quote">Is this Swap the same seal as the Si to ZC swap?</TD></TR></TABLE>
If you're talkin about the black top dohc zc,or sohc zc into the 88-91 chassis...yeah
If you're talkin about the sohc vtec zc then its the same except you have to add the 4 wires for vtec and get a vtec controller or vtec ecu..
People askin some broad as questions lately..
What tranny are you going to use? If you use the ZC or the SI you will have to change the hubs to Si or DX. The HF hubs are too small for the Si or ZC axles.
Im going to put a DOHC ZC into it. Im going to use the ZC ECU and transmission. The thing Is that I bought the HF with a DX engine swap in it. Am I going to have to do the swap as if it was a DX?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yomomz »</TD></TR><TR><TD CLASS="quote">Im going to put a DOHC ZC into it. Im going to use the ZC ECU and transmission. The thing Is that I bought the HF with a DX engine swap in it. Am I going to have to do the swap as if it was a DX?</TD></TR></TABLE>
It should still be mpfi..
I dont think anyone could be that stupid to convert mpfi to dpfi just to run a dx motor..
You would think they would just put the hf manifold on the dx motor..Or maybe its a dx motor from a 92+ civic and its already mpfi..
Check it out first..
MyRex
Jan 6, 2003 10:27 AM
