US Spec B16A2, B18 and B16 Cable Trannies????????? Will they work?
Old Dec 17, 2004 | 10:13 PM
The DX Rex's Avatar
Default US Spec B16A2, B18 and B16 Cable Trannies????????? Will they work?
basically i have a crx si with a b18b1 in it with a 90-93 teg LS cable tranny. bascially i am gettin a U.S. Spec b16a2. will my ls cable tranny work with it until i get my b16 cable tranny? i thought it would but my friend said it wouldnt so i thought id ask the experts. and i kno i need an ecu and dizzy as well but im worried about the tranny for right now.
Old Dec 17, 2004 | 10:23 PM
StorminMatt's Avatar
Default Re: US Spec B16A2, B18 and B16 Cable Trannies????????? Will they work? (nyhustla2k)
The transmission will work. But the gearing will suck. Also, depending on whether the transmission is 1990-1991 or 1992-1993, you may need a new clutch disk.
Old Dec 17, 2004 | 10:50 PM
Ray-mond's Avatar
Default Re: US Spec B16A2, B18 and B16 Cable Trannies????????? Will they work? (StorminMatt)
It will work I have that set up right now I us a flywheel from a 95 delsol dohc vtec and a clutch kit from a 95 del-sol Dohc vtec if you us the ls clutch it will work as well but it will not hold up if you plan on racing it.
Old Dec 18, 2004 | 12:50 AM
JapJunkie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">The transmission will work. </TD></TR></TABLE>
Old Dec 18, 2004 | 03:01 AM
SicRx's Avatar
all b series trannys are compatable. it just depends on cable or hydro if you need a conversion kit. ls trannys suck *** in gearing. only thing they got is a ong 5th gear. go with b16 tranny with lsd
xmattx
Jul 28, 2009 01:11 PM
ef9civicgen4
May 29, 2008 03:26 AM
luvs2spooge
Aug 31, 2007 06:34 AM
g2lsv
Nov 22, 2004 10:52 AM
S13 slide
Aug 10, 2003 04:33 PM
