Honda S2000 Honda S2000
5 zigen rims
Old Dec 17, 2004 | 04:31 PM
s2k_boy's Avatar
Default 5 zigen rims
is the 5 zigen cospe wheels ''18-''7.5 5-114 pcd offset fit the s2k??? thats front n rear.
Old Dec 19, 2004 | 02:18 PM
papa5murf's Avatar
Default Re: 5 zigen rims (s2k_boy)
i believe they do have the proper offsets for these wheels........ but you want to go with the wider one for the rears....
Old Dec 19, 2004 | 09:23 PM
s2k_boy's Avatar
Default Re: 5 zigen rims (03s2kblue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">i believe they do have the proper offsets for these wheels........ but you want to go with the wider one for the rears....</TD></TR></TABLE>
do you a rims for ur car??? wat size are they???
Old Dec 21, 2004 | 11:46 AM
papa5murf's Avatar
no i dont' have rims for my car at the moment.. .but i'm going with 18x7.5 front and 18x9 in the rear..maybe 18x9.5 in the rear if i go with the work meister s2r
Old Dec 21, 2004 | 12:01 PM
papa5murf's Avatar
ok here we go....
if you want the 5zigen 5zrcorse
18x7.5 +35, +39, +49
18x8.0 +33, +38, +43, +46,
18x9.0 +24, +32, +37, +44, +45,
18x10.0 +39, +44
i know of people that have gone with 8.5 in the rear with +46 offset... it does rub a little.... but you might be ok.... it'll also depend on your drop.....and obviously the 18x9's will not work on the car.. this is the 2 piece version by the way.. which is the only one thats going to give you a larger then 7.5 width..... so maybe if you can find a good vendor they might be able to customly make you the wheels with the proper offsets....
Old Dec 21, 2004 | 12:58 PM
s2k_boy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">ok here we go....
18x10.0 +39, +44
i know of people that have gone with 8.5 in the rear with +46 offset... it does rub a little.... but you might be ok.... it'll also depend on your drop.....and obviously the 18x9's will not work on the car.. this is the 2 piece version by the way.. which is the only one thats going to give you a larger then 7.5 width..... so maybe if you can find a good vendor they might be able to customly make you the wheels with the proper offsets....</TD></TR></TABLE>
right on s2k buddy
Civic2.2ss
Honda Civic (2006 - 2015)
May 9, 2019 11:12 AM
jawsk2
34
Feb 1, 2009 08:31 PM
SimbaDogg
Honda S2000
18
Apr 16, 2005 07:29 PM
MooreBoost
Honda S2000
Nov 24, 2003 04:45 PM
