6th gens w/ Ground Control coils
sup guys
my friend has a 6th gen accord v6 ex....he dropped his ride about 2.5 inches w/ GroundControl coils and now needs to raise it for an emmisions test....
for those of u who have these coils or know about them could u please tell me as detailed as possible instructions on how to raise his car? we don't know much about anything so as much info as u can give will help out a lot! pics would be awesome if available much thanx in advance
Probably needs to raise it to clear the dyno drum (yes, our emissions tests are on a dyno here, but they don't measure cool stuff like horsepower and torque).
Anyways, you've gotta lift the car (or jack up one corner at a time) to unload the suspenion. With the suspension dangling, loosen the alan screw in the Groundcontrol colar (should be the golded thing wrapped around the red threaded sleeve). Once this is loosened, you can twist the colar. To raise the car, twist the colar UP. The higher you put the collar the higher the car will sit. You can probably go too high and make the car look like an off road vehicle. Just twist the collar until it's around 2.5" higher than its starting position.
HTH
HTH
Boy, I am I glad Fl decided to do away with emissions..............less hassles...........the state finally emitted it was a waste of $ and time, b/c it didnt do anything
sorry i think every1 misunderstood....uh so for the emmissions test u will roll ur car onto these wheel thingies that will keep ur car in one place while the dude "drives" ur car.....basically just wheels moving while they measure the **** ur car emits.....uh well either way even if u don't need to raise it i'd like to know how cuz he wants to do it whehter its for the test or not
beatbox22
May 25, 2009 08:17 PM
Chronicsinners
Jan 16, 2003 04:12 AM
