Does this sound like something loose?
Old Dec 17, 2004 | 10:04 AM
VM 2's Avatar
Default Does this sound like something loose?
Heres the situation: I got a 97 Civic Ex Coupe, and sometimes when i hit a hard bump, i can hear the driver side front spring make like a boing/thunk noise. What do you think this sound is? Sounds more like a boink...... but i think its coming from the spring.
Oh, this is stock strut/spring btw.
Old Dec 17, 2004 | 10:11 AM
huntarrr's Avatar
Default Re: Does this sound like something loose? (VM 2)
Probably not coming from your springs/struts.
Most likely its your CV joints.
VM 2's Avatar
Default Re: Does this sound like something loose? (vsm98civic)
why would it make that noise? i just replaced that axle too
Old Dec 17, 2004 | 10:14 AM
huntarrr's Avatar
does it come when you're turning the wheel? only happens with one side? does it matter how fast you're going?
if you think its your spring, take your wheel off and check to see that the spring is lined up properly.
Old Dec 17, 2004 | 10:17 AM
VM 2's Avatar
Only one side, the drivers side.
Happens when going straight.
Doesn't matter how fast.
Old Dec 17, 2004 | 10:22 AM
Pioneer162's Avatar
please upload mp3 or video
Old Dec 17, 2004 | 10:54 AM
Lee_Delso's Avatar
Default Re: Does this sound like something loose? (Pioneer162)
Ball joints? Or when you did your axles you forgot to tighten all bolts? Check your tie rod also.
Old Dec 17, 2004 | 12:24 PM
mattharper's Avatar
could also be a bad wheel bearing
solex
Honda Civic (2001 - 2005)
28
Oct 16, 2010 05:48 PM
stevescivic
May 4, 2008 08:15 PM
c.dub
Suspension & Brakes
Apr 18, 2007 04:55 PM
rivoe302er
Apr 3, 2007 09:09 PM
joshalee
Apr 30, 2004 08:45 PM
