WaterPump Tstat HeaterCore oh my!
Old Dec 17, 2004 | 08:05 AM
kruthles's Avatar
Default WaterPump Tstat HeaterCore oh my!
There is some weird CRX heating voodoo going on in my car
When the car is running the temp gauge goes to warm at its regular pace, when the temp gauge is sitting at warm there is still no heat in the car. A few more miles down the road the heat will start getting warm after this point the heat will just go from warm to cold, warm for a few minutes then colder again then back to warm, the temp gauge In the car stays steady the whole time this is happening. Over a few weeks it has gotten worse and worse now I rarely get warm air from the vents anymore. I have even tried a nice peice of cardboard infront of the radaitor with little sucess.
I looks like my water pump is starting to go bad, makes some nice noises and has started to leak some you think the water pump beginning to fail could cause this sort of problem? Or is some else at fault here. the car has NEVER shown any signs of overheating and the gauge seems to be working fine(ran car with fan unplugged and it went up).
My only other shots in the dark are the Tstat working really really weird or some chunk of nastyness floating around my cooling system clogging when it pleases.
Has anybody seen a problem like this before?
Old Dec 17, 2004 | 09:15 AM
mike93eh
Guest
Posts: n/a
if the waterpump is leaking, go ahead and fix that.
but if you need a heater core. i have one for sale.
Old Dec 17, 2004 | 10:30 AM
Bgladfelter's Avatar
I've had something clog my heater, but it happened when I was bypassing it, and the two ports were open for a few months.
Thermostat may be acting up, but replace it and the water pump, and make sure to bleed the system afterward.
Old Dec 20, 2004 | 07:42 AM
kruthles's Avatar
Default Re: WaterPump Tstat HeaterCore oh my! (kruthles)
It was the water pump guys
I swapped it out friday night and now its working great again
finally a car wit HEAT
Old Jul 29, 2005 | 07:03 AM
b18_crx's Avatar
I have a similar problem but my temp gauge goes to cold only when i get on it after like 4500 rpm. when i drive normal the temperature is normal without any problems what could cause this......water pump doesnt leak no noises? im stumped
Old Jul 31, 2005 | 09:29 AM
b18_crx's Avatar
Default Re: WaterPump Tstat HeaterCore oh my! (b18_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18_crx &raquo;</TD></TR><TR><TD CLASS="quote">I have a similar problem but my temp gauge goes to cold only when i get on it after like 4500 rpm. when i drive normal the temperature is normal without any problems what could cause this......water pump doesnt leak no noises? im stumped</TD></TR></TABLE>
fixed.............needed new radiator and fan was not working.....replaced relay no more overheating!
crazyhouse2011
Nov 22, 2014 03:14 AM
lilo_goki
Mar 27, 2011 09:38 AM
Weak!EG
Feb 19, 2010 01:59 PM
supaf1y
Jul 9, 2009 06:08 PM
otakueric
May 6, 2004 07:17 PM
