SRS light on 94 civic please help
Old Dec 17, 2004 | 07:22 AM
dwn4cause's Avatar
Default SRS light on 94 civic please help
Hi, I have a 94 civic with a ls/vtec swap.. i unpluged my fuel relay and pluged it in.. after 5 min driving the srs light is on, even though I didn't do anything to the airbags, I tried to reset the ecu but no luck any one know how to diagnos the problem? thanks
Old Dec 17, 2004 | 07:41 AM
jones88's Avatar
Default Re: SRS light on 94 civic please help (dwn4cause)
The same thing happend on my prelude, did you already try disconnecting the neg battery terminal for 10- 15 min? That turned off the SRS light on mine
Old Dec 20, 2004 | 08:12 AM
chameleon's Avatar
Default Re: SRS light on 94 civic please help (jones88)
there is a way to reset the SRS light, there is a plug on the fuse box under the dash that has a dummy srs plug which is yellow, you have to jump that when the car is off and put the car to ON, then keep looking at the light, when it goes off, take out the jump when it comes back put it back in, and so on until you see the light blink a few times then turns off the system is now reset. if nothing is wrong with the airbags it will stay off.
Jason Green
Oct 31, 2016 03:29 PM
mikeyboost
Mar 26, 2008 08:45 AM
SiR AuToBoT
Apr 5, 2005 05:50 PM
NJcivic21
Feb 4, 2005 02:22 PM
