weird question about adjusting Koni Yellows
Hey guys,
I was just adjusting my Koni Yellows when I thought about something. Would it make any difference if I adjusted the shocks with the car on the ground or from up in the air? would it matter if the shock was partially compressed (car on ground) or if the shock was not compressed at all (car in the air)?
I was thinking that it probably dosen't make a difference, but I just thought I'd check.
TIA
TIA
For those of us running the '88 rear dampers which are not externally adjustable, the piston must be fully compressed for adjustments. The externally adjustable Konis (with the little white ****) do not have to be compressed or extended to be adjusted as far as I know.
Double check by asking this guy: https://honda-tech.com/zero...27915
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by travis »</TD></TR><TR><TD CLASS="quote">For those of us running the '88 rear dampers which are not externally adjustable, the piston must be fully compressed for adjustments. The externally adjustable Konis (with the little white ****) do not have to be compressed or extended to be adjusted as far as I know.
Double check by asking this guy: https://honda-tech.com/zero...27915</TD></TR></TABLE>
COOL!!! thanks for the info and giving me that guys info. I'll contact him and see what he says.
Heh, i have an 88 using external adjustable Koni Yellows.
HONDA 88 Civic, CRX (Exc.Wagon)
<U>Front </U> <U>Rear</U>
8041 1166SP4 8041 1164Sport
<taken from http://www.koni-na.com>
Work great
Jon
Work great
Jon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX-Fluffy »</TD></TR><TR><TD CLASS="quote">Heh, i have an 88 using external adjustable Koni Yellows.
Which ones are they and where did you get them? I heard rumors that they were available in the European market, and Koni can do the conversion in their shop. I would love to have that option for my rears.
