REbuilt gearbox - installed, now car will not turn on...
Hi guys - a strange problem here...
1 week ago , i removed my 1992 honda civic HB gearbox to rebuild ( bearings + synchro etc) . Due to some parts that needed to be ordered in , the car was left on jackstands and battery disconnected for 1 week.
Last night , myself and a friend re-installed the gearbox + new main seal + axle seals and lubed the lot up + tightened every bolt etc. We went over the lot - starter in and ready to go . I turned the key , I could hear the fuel pump pre-pressurize and then the usual "click". I turned the key - and ......"whirrrrrlllllllllllllllllllllllllllllll" .
The engine isnting iginiting ?!?
*update* Ive checked starter ( engine is turning TRYING to compress and ignite but no fuel ?!?) , dizzy+igniting system - all is working fine. I tried to clutch start too - but it WONT turn over.
What has happened ? Any ideas ? IT is either fuel related , or something i have no idea about - BUT for sure it has happened in the last week ?!?
Could the cylinders be flooded ? BAH im going crazy from stress here...
Anything ive missed...help
i do not recall.....myself and a mate did it so possbily he did - Where on the thermostat is the groudn cable ?
Thanks
Thanks
its on one of the bolts on the thermo housing. if you look you will see it. same thing happened to me before and thats what it was. check all of you grounds
good luck
good luck
[QUOTE=Wynode]Would it be one of the set of the wires that are held by the two bolts in the middle of this pic?
yes
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude »</TD></TR><TR><TD CLASS="quote">[QUOTE=Wynode]Would it be one of the set of the wires that are held by the two bolts in the middle of this pic?
yes</TD></TR></TABLE>
Thanks guys - Thermo ground is securely on.
Car will no start still - update is , ive had a look inside each combustion chamber ( via takign out spark plug etc) and there is a light wetness look to the cylinder heads - perhaps excess oil or soemthing not lettign the car start correctly ?
Ive tried starting with WOT , to correct "flooded " condition - the car ALMOST starts and blows abit of grey smoke. . . i still dont realyl have an idea.
jrclarkey
Honda CR-V & Element
Feb 5, 2014 04:12 PM
dc2LS
Mar 27, 2011 01:54 PM
