b16 ecu
Old Dec 16, 2004 | 09:01 PM
folta2169's Avatar
Default b16 ecu
I have a b16 swap for my 89 si crx. I need to know if the ecu will plug into the plugs already there. Also if it will plug right in, is it posible to put the ecu in before the swap is put in.
Old Dec 16, 2004 | 09:59 PM
Redline130's Avatar
Default Re: b16 ecu (folta2169)
The B16A ecu will plug into your harness. You could use it, but you would get a check engine light because you don't have VTEC.
Old Dec 17, 2004 | 05:51 AM
evad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by folta2169 &raquo;</TD></TR><TR><TD CLASS="quote">I have a b16 swap for my 89 si crx. I need to know if the ecu will plug into the plugs already there. Also if it will plug right in, is it posible to put the ecu in before the swap is put in.</TD></TR></TABLE>
Yeah it will plu right in but..........you will have to wire up the vtec solenoid, vtec pressure switch, knock sensor, and o2 sensor. Have fun, it's worth it!
Old Dec 17, 2004 | 09:18 AM
smart monkey's Avatar
if the ecu is a OBD0 PR3 or PW0 then it will plug in but you will need to add wires for vtec, vtec oil press switch, knock sensor, second O2. you can make this setup or hasport makes a subharness that makes it easy to do.
pro_status
Aug 29, 2008 07:20 PM
BlUAc
Sep 6, 2006 09:32 PM
Jose-aka-Pedro
May 18, 2006 09:50 PM
SkunkCrxSi
Jul 26, 2004 05:58 AM
y_do_u_want_gio
Jan 4, 2003 07:32 AM
