GSR crank vs LS crank
Old Dec 16, 2004 | 08:40 PM
jdmsijdm's Avatar
Default GSR crank vs LS crank
in a b18a. Which would be better and why? And if installed installed in a b18a do the rods have to match the crank? I mean will LS rods fit on a gsr crank in this block and vise versa? Someone help, my topics usually get ignored.
Old Dec 16, 2004 | 09:12 PM
rodimus's Avatar
Default Re: GSR crank vs LS crank (jdmsijdm)
holy crap didn't someone just ask the same thing?
LS crank = LS rods
GSR/ITR crank = GSR rods or ITR rods
LS CRANK/RODS a little more low end with less potential for high rpm power, and less stable at higher rpms as well.
GSR crank/rods almost opposite of what i said of the LS CRANK/RODS
Old Dec 17, 2004 | 02:37 AM
PyroProblem's Avatar
Default Re: GSR crank vs LS crank (EVOL)
ls crank will give a bit more displacement and youll probably hit peak power sooner and get a bit more of it...
Id keep it under 8500 rpms though...
9k or higher use the gsr crank(less stroke).
You must match the rods w/ the crank...unless your gonna buy some $$custom$$ pistons...
Old Dec 19, 2004 | 10:53 AM
chameleon's Avatar
Default Re: GSR crank vs LS crank (PyroProblem)
also if you decide to use an LS crank and rods in a gsr block you have to remove the oil squirters and plug them up otherwise they will hit, so basically just a tad easier to go with LS block if your using the LS crank/rods anyways.
carlossolorzano
May 27, 2012 01:12 AM
swapped95
Aug 18, 2007 06:51 PM
bigbadboy
Aug 28, 2006 06:20 PM
Kelly.
42
Oct 18, 2005 11:14 PM
