stock compression ratio
Old Jan 4, 2002 | 09:20 AM
laughinxxx's Avatar
New User
Default stock compression ratio
What's the stock compression ratio in the H22A1? I'm trying to figure out how high of cr I can go with forged pistons before I have to use race gas when I spray nitrous.
Old Jan 4, 2002 | 09:35 AM
JG Luder's Avatar
Default Re: stock compression ratio (laughin2.2)
After talking to Warren, he knows someone who did 11.5:1 and happy gas. I'd stick with 10:1 or 10.5:1 for safety sake... you don't have the luxury of $$$ to back you up when things go wrong.
Old Jan 4, 2002 | 09:53 AM
laughinxxx's Avatar
New User
Default Re: stock compression ratio (JG Luder)
People on SHO have ran DP kits on on ITRs, so I know the 10.5:1 is safe. I really want to run 11:1 to gain some extra hp when I'm not spraying, but what is the stock cr?
Old Jan 4, 2002 | 01:34 PM
Blownlude's Avatar
New User
The H23 motor is 9.8:1 I believe stock for the VTEC is less than that.
Old Jan 4, 2002 | 01:36 PM
JG Luder's Avatar
Default Re: stock compression ratio (Blownlude)
um... actually, the stock USDM H22A1 and A4 is 10:1.
Old Jan 4, 2002 | 01:49 PM
laughinxxx's Avatar
New User
So 11:1 is up there a bit. That extra 15 hp would be nice though.
Old Jan 4, 2002 | 01:55 PM
JG Luder's Avatar
more along the lines of an extra 8-12... depending on what you have done. My +13:1 was crazy.
Old Jan 4, 2002 | 01:58 PM
laughinxxx's Avatar
New User
Is 11:1 fine with 93 octane?
Old Jan 4, 2002 | 07:37 PM
Greyout's Avatar
I have the JDM motor, which runs around 10.6:1 . My ignition is advanced to 19 degrees (15, +/-2, is stock). On 93 octane I have no problems, although I think the knock sensor has tripped a few times, but before I could hear ping.
Old Jan 4, 2002 | 07:48 PM
laughinxxx's Avatar
New User
Default Re: stock compression ratio (JDM LUDE)
Not bad. There may be hope for my 11:1 cr yet.
Old Jan 6, 2002 | 08:06 PM
akkording's Avatar
New User
My block is in the machine shop getting .25 OB Type-S pistons (11:1 CR) I was planning on using a 80 shot direct port kit I have sitting in my garage. It can be done! Just get the timing and fuel right or else say good bye to happy times.
civicsirii
Sep 12, 2018 07:11 AM
meanshyguy
Apr 1, 2007 10:23 AM
B16b-EJ8
24
Aug 5, 2006 12:24 AM
11sec CR-X
Sep 19, 2004 08:24 PM
90da4dr
Mar 9, 2003 05:18 AM
