Bracket, Bolts, Bushings, Misc Stuff for ITR, EK, EG, DC
<FONT SIZE="2"><FONT COLOR="DarkGreen">All Prices & Description are Listed Below, **<u>I Will Update the list, If I see anything else.</u>.</FONT></FONT>.
Have a lot References. Money Order or Paypal only. Im paypal premier verified user for over 4yrs. *please add paypal fees for paypal user. Pictures are Available.
* <u>S/H is extra outside So.Cali/Los Angeles area</u>.
email me at egjoe@hotmail.com
<FONT COLOR="DarkPurple"><u>D-Series EK</u>.</FONT>
a) 00 Civic Si Pipe Hydraulic Line (No Rubber Line) $10 + SH
b) 00 Civic Si Pipe Hydraulic Line w/ Rubber Line $20 + SH
c) 97 Civic Power Steering Bracket $20 + SH
d) 00 Civic Si Resonator 2pc Black & White Piece/Not In good cond. $20 + SH
e) 00 Civic DX Door Lock (Held by 3 bolts) $29 + SH (WONT Seperate)
f) 00 Civic DX Inner Door Handle in Gray & Light Gray $29 + SH (WONT seperate)
g) 00 Civic DX "B-pipe" for HB/Coupe Only $59 (Local Only)
<FONT COLOR="DarkPurple"><u>D-Series EG</u>.</FONT>
a) 94 Civic Bracket for Radiator $15 + SH
b) 94 Civic Bracket Z6 Upper Bracket Header w/2 bolts $15 + SH
c) 92 Civic Driver Si Mount (Rubber part) $15 + SH
c) 94 Civic Rear Tranny Bracket $20 + SH
d) 94 Civic Front Lower Tranny Bracket $20 + SH
e) 94 Civic Power Steering Bracket $20 + SH
f) 94 Civic Si/EX Resonator for Intake 2pc $25 + SH
g) 94 Civic Left & Right Front Lower Bushing, Not Torn. $29 + SH
h) 94 Civic Bracket-End for the Dash 2pc $29 + SH
i) 94 Civic Si Water Temp Housing w/sensor $29 + SH
j) 94 Civic Si/EX Caps for the Shocks w/Bushing $29 + SH (WONT Seperate)
k) 94 Civic Si/EX Reservoir Container w/Bracket for Radiator $29 + SH (WONT Seperate)
l) 94 Civic Si/EX Left ~ Driver Side Lower Control Arm (had hole for swaybar) $29 + SH
m) 94 Civic Si/EX Front Swaybar w/2 Endlinks $39 + SH (WONT Seperate)
n) 94 Civic EX Right~passenger side Window Regulator with Motor $39 + SH
o) 94 Civic VX Factory Exhaust Upper/Lower Manifold with Cat will fit CX. (NO O2/NO Shield) $79 + SH (WONT Seperate)
<FONT COLOR="DarkPurple"><u>B- Series ITR</u>.</FONT>
a) 00 ITR Bracket for TB $10 + SH
b) 00 ITR Bolts for Timimg Belt 8pc $15 + SH
c) 98 JDM ITR Bushing for rear swaybar 23mm $15 + SH
d) 98 JDM ITR Bushing for rear swaybar 23mm & "O" ring bushing $20 + SH
e) 00 ITR Cam gears 2pc $25 + SH
f) 00 ITR Subframe ROD ~ goes on the Subframe will fit EG Subframe $25 + SH
g) 98 JDM ITR Bracket for JDM 4-1 $25 + SH
h) 98 JDM ITR Heat Shield for Cat 2pc $25 + SH
i) 00 ITR Rear Lower Tie Bar $29 + SH
j) 00 ITR Front ABS sensor $29 + SH
k) 00 ITR Left ~ Driver Side Upper Control Arm $29 + SH
l) 00 ITR Bracket for Fuel Filter & Fuel Filter 8K miles $29 + SH
m) 00 ITR Seat Belts for the Rear 4pc $49 + SH (WONT Seperate)
n) 00 ITR Bracket/Stay In for Intake manifold w/Black Box~Chamber $59 + SH(WONT Seperate)
o) 00 ITR Charcoal Canister w/Sensor and Rubber Line $59 + SH (WONT Seperate)
<FONT COLOR="DarkPurple"><u>B- Series GSR/B16</u>.</FONT>
a) 00 B-Series Oil Dip Stick $5 + SH
b) 94-00 GSR Bracket for Center Console (Rear Section) $5 + SH
c) 00 Civic Si Bracket for TB $10 + SH
d) 94-00 GSR Rear Seat Bracket 2pc $10 + SH
e) 00 Civic B16/GSR Bracket for the Header $10 + SH
f) 94-00 GSR "O" Ring for the front Lower Shock $15 + SH
g) 94-00 GSR TB Cable $20 + SH
h) 94-00 GSR Dust Shield for the Tranny $20 + SH
i) 94-00 GSR Fuel Rail (Bare) No Injector/NO FPR $20 + SH
j) 92-95 B16 Fuel Rail w/FPR NO Injector $20 + SH
k) 94-00 GSR Bracket for the E-Brake Line (L Shape) 4pc $25 + SH
l) 94-00 GSR Spark Plug Wires $25 + SH
m) 94-00 GSR Mount for Driver Side Upper ~ Block Side w/2 studs $25 + SH
n) 94-00 GSR Bracket Alternator Top & Lower $29 + SH (Add $5 for the 2 Alternator bolts)
o) 94-00 GSR Bracket for Power Steering $29 (Add $5 for the 2 PS bolts)
p) 94-00 GSR Bracket Holder for Rear e-brake Line $29
q) 94-00 GSR Heat Shield for Rear Brakes $29
r) 94-00 GSR Front & Rear Brake Hose $29
s) 94-00 GSR Bracket for the Heater $29
t) 94-00 GSR Rear Swaybar w/Endlinks & 2 D Bracket/D Bushing $49 (WONT Seperate)
3rdman
Jun 22, 2007 09:08 AM
