any HowTo on how to remove instrument cluster from 98 civic? (new lights)
Old Dec 16, 2004 | 07:12 AM
multiplex's Avatar
Default any HowTo on how to remove instrument cluster from 98 civic? (new lights)
I bought my friend some new lights and wanted to install them for him.
could anyone provide a how to on what needs to be removed to access the back of the cluster?
Thanks guys! :D
Old Dec 16, 2004 | 07:16 AM
ian.'s Avatar
Default Re: any HowTo on how to remove instrument cluster from 98 civic? (multiplex)
its easy this will probably help u a little http://www.team-integra.net/se...ID=84 its two screws for the plastic piece then pull on it it because it is clipped in two then after thats off there will be 4 screws holding the cluster in 2 on each side clearly visable
Old Dec 16, 2004 | 07:17 AM
snatch's Avatar
I don't have any pics, but words might help.
Tools needed:
Phillips screwdriver
- Remove the black bezel around the gauge cluster by removing the 2 screws in the upper portion of the bezel.
- Pull the bezel out from the cluster, there are 2 clips at the bottom you will have to overcome.
- There are then 4 gold screws holding the cluster in. Remove these and the cluster will come out.
- Remove the plugs at the back, and you can fully remove the cluster from the car.
edit: beat by a minute
Old Dec 16, 2004 | 07:27 AM
multiplex's Avatar
Default Re: any HowTo on how to remove instrument cluster from 98 civic? (******)
oh lordy... heh it's much easier than i thought it would be then... yikes!
on my maxima I have to remove the bezel, but also remove the bottom part of the stearing wheel cover (where your feet are located) then I can remove the strearing column piece which allows me to remove another part... lol
then again my bezel is slightly busted, so in my case I just pull the bezel out and that's it... hehe
But yeah, cool! I didn't realise it was so simple!
Thanks guys! VERY quick response!!
Old Dec 16, 2004 | 08:08 AM
ian.'s Avatar
no problemo
civic_ek9
Mar 29, 2003 06:54 PM
LillDragun
Jul 13, 2002 08:15 PM
