half-sized fluidyne radiator for crx?
Old Dec 16, 2004 | 06:38 AM
b18-c-rx's Avatar
Default half-sized fluidyne radiator for crx?
Is anyone here running a half-size fluidyne radiator for the CRX?
Ive seen a few websites that say "comes with all brackets needed, fits like OEM radiator"
that's not good enough for me - does it actually bolt up or do I have to fabricate something?
Does it fit perfectly? someone said that the coolant (lower) hose hits the crossmember
any general opinions on this radiator?
Old Dec 16, 2004 | 07:09 AM
slowpokesi's Avatar
Default Re: half-sized fluidyne radiator for crx? (b18-c-rx)
get the c&r shorty, they make a half size radiator specifically for a crx!
Old Dec 16, 2004 | 09:56 PM
b18-c-rx's Avatar
Default Re: half-sized fluidyne radiator for crx? (slowpokesi)
do you know if c&r will fab my coolant pipes so that I wont have that ugly bend wiht my b18 swap
Old Dec 16, 2004 | 10:06 PM
Rostr02's Avatar
also is the C&R crx rad a dual or single core. If it is a dual core half size where can I buy it.
Old Dec 16, 2004 | 10:43 PM
Redline130's Avatar
Default Re: half-sized fluidyne radiator for crx? (Rostr02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rostr02 &raquo;</TD></TR><TR><TD CLASS="quote">also is the C&R crx rad a dual or single core. If it is a dual core half size where can I buy it.</TD></TR></TABLE>
I know that Wil from Exospeed carries them, they are a bit pricey however. I was thinking of getting one, but I think I'll just get a 92-95 Civic radiator and angle it to fit.
Old Dec 16, 2004 | 11:08 PM
DocSean's Avatar
Default Re: half-sized fluidyne radiator for crx? (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">
I know that Wil from Exospeed carries them, they are a bit pricey however. I was thinking of getting one, but I think I'll just get a 92-95 Civic radiator and angle it to fit.</TD></TR></TABLE>
Can't you just use the half-size radiator from the EG's? Or do you have to make the proper modifications?
Old Dec 17, 2004 | 06:16 AM
QUiKSR20's Avatar
Default Re: half-sized fluidyne radiator for crx? (spankjelly)
EG rad is too tall. Has to be angled. Alot of people are having good luck using 95-99 Neon Rads ( no ac and manual trans ) width and thickness of an EG basically and not too tall will use 2 oem crx mounts. Just need to run an inline adapter for the fill cap. But its a cheap easy bolt on upgrade!
Old Dec 17, 2004 | 06:23 AM
azulito's Avatar
Default Re: half-sized fluidyne radiator for crx? (QUiKSR20)
Use the Neon rad if times are tough. Use the C&R if you need the dual core and have a little extra for your project. C&R will make it anyway you want it if you have the $ to go custom. You will need to supply dimensions. I used the C&R and it fits great. I used it with a Z10 crossmember so I'm not sure what you will need to do to your stock crossmember. I am pretty sure drilling ONE hole in crossmemeber is all. As with anything a little massaging is usually needed.
The information doesn't seem to be getting out there...92+ 1/2 civic rads and all thier aftermarket versions are TOO TALL for an EF without titling back or some hood modifications.
Will at Exospeed helped make it all possible for me.
After looking at the Fluidyne site I see no info on a 1/2 sized CRX-EF rad. Just full width. Correct me if I'm wrong.
Old Dec 17, 2004 | 06:48 AM
Doodoo's Avatar
https://honda-tech.com/zerosearch
Click archived
Type "radiator crx"
All your answers are there.
Old Dec 17, 2004 | 10:04 AM
turbotommy's Avatar
Default Re: half-sized fluidyne radiator for crx? (Doodoo)
pwr cvic half will fit. i had one in my 4dr integra and it fits perfectly in my 91' crx...i do have a jdm hood though.
Old Dec 17, 2004 | 11:37 AM
92integra_gs's Avatar
with minor mods you can fit a EG half rad in the rex
Old Dec 31, 2004 | 12:05 AM
YashiMotors's Avatar
Default Re: half-sized fluidyne radiator for crx? (azulito)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azulito &raquo;</TD></TR><TR><TD CLASS="quote">
After looking at the Fluidyne site I see no info on a 1/2 sized CRX-EF rad. Just full width. Correct me if I'm wrong.</TD></TR></TABLE>
FHP11-88CRX * 88-91 CIV/CRX 38mm Radiator
This is a halfsize radiator for CRX 88-91, anybody tried this? I allso need to know if it filts bolt on.
Old Dec 31, 2004 | 06:42 AM
Default Re: half-sized fluidyne radiator for crx? (YASH)
no one?
Old Jan 1, 2005 | 07:22 AM
azulito's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YASH &raquo;</TD></TR><TR><TD CLASS="quote">FHP11-88CRX * 88-91 CIV/CRX 38mm Radiator
This is a halfsize radiator for CRX 88-91, anybody tried this? I allso need to know if it filts bolt on. </TD></TR></TABLE>
I am sure that the rad you are mentioning is full length. Th epicture is decieving you. Did you actually contact them?
If you are willing to spend the $ for a fluidyne then why not just get the C&R which is made for a CRX and is half the width. Trust me. The passenger side pin will fit right into your crossmember, then drill a hole for the middle pin (formerly the drivers side)
http://www.exospeed.com should be able to help you, or contact C&R directly.
Old Jan 8, 2005 | 03:47 AM
http://www.exospeed.com should be able to help you, or contact C&R directly.</TD></TR></TABLE>
Ben at Importparts told me that it was halfsize and he has spoked with them.
Do you have any website for C&R ?
Old Jan 12, 2005 | 05:29 PM
Ben Huynh's Avatar
Fluidyne makes the 88-91 Civic/CRX radiator in full and half size.
Old Jan 17, 2005 | 11:40 AM
Default Re: half-sized fluidyne radiator for crx? (ben@importparts.com)
This is what Fluidyne said about the CRX radiator.
Anybody here that has tried doing this? Any pictures?
"We actually do produce a 1/2 size radiator that will fit the '88-'91 Civic and CRX. It is basically the same as the '92-'00 Civic radiator, but has the mounting pins relocated to better fit the earlier models. You will need to relocate the upper mounting bracket that fits over the pin, and you will also need to use the '92-'00 Civic fan package. The '90 model fan package will not work with this half size radiator. The part number you would need is FHP11-88CRX.5 ´"
crxmadness
19
Dec 2, 2009 10:48 PM
SupraRXZ
Dec 18, 2006 04:30 PM
3s0n3
11
Feb 12, 2006 05:08 PM
BoostedCivicEJ8
Jul 2, 2005 07:21 AM
