Wheel hop on acceleration.
Old Jan 4, 2002 | 04:42 AM
NunRacer's Avatar
Default Wheel hop on acceleration.
Once and a while under hard acceleration I will get a lot of wheel hop especially
in first when I hit VTEC. This seems to happen more often when the road is a bit
wet as well. My car has been lowered with H&R springs about a inch and a half.
Usually I have let off the gas to stop this and on occasions with all the vibrations
the glove compartment has opened. The car has under 19,000kms(11,800Miles).
Would stiffer bushings or new springs help? Any help is appreciated.
Old Jan 4, 2002 | 04:43 AM
Willard's Avatar
Default Re: Wheel hop on acceleration. (NunRacer)
Motor mount inserts are your friend.
Will
Old Jan 4, 2002 | 04:53 AM
Jason's Avatar
also try the Z10 radius bars... http://www.z10eng.com
Old Jan 4, 2002 | 05:02 AM
Willard's Avatar
Default Re: Wheel hop on acceleration. (typer98)
$50 vs. $400 hrmmm
Will
[wrong price]
[Modified by Willard, 9:03 AM 1/4/2002]
Old Jan 4, 2002 | 05:05 AM
NunRacer's Avatar
Default Re: Wheel hop on acceleration. (Willard)
The motor mont is 50 right? How exactly does that help?
Old Jan 4, 2002 | 05:06 AM
2k1TypeR0610's Avatar
New User
If you want to feel more vibrations through your steering wheel at idle(inserts), or not(Z10).
Z10
Old Jan 4, 2002 | 05:12 AM
B18CXr's Avatar
Default Re: Wheel hop on acceleration. (2k1TypeR0610)
z10 or not, inserts are a must if you drive the car hard....better feel and yes they are noisy but WGAF!?
Old Jan 4, 2002 | 05:14 AM
Slater's Avatar
Default Re: Wheel hop on acceleration. (B18CXr)
I agree...I actually have both. Wheel hop - what's that?
Z10
Poly motor mounts
- Slater
Old Jan 4, 2002 | 05:29 AM
Willard's Avatar
Price varies from place to place. (~$50 US)
Check out this site... http://www.energysuspension.com
They help by filling the open spaces left when the OE mounts were molded.
Z10 may be good for drag racing... but for road racing... having the motor stay close to it's original position is a good thing.
Next time you visit a dyno... check out how much the motor moves during a pull. Kinda scary... and the ZEE-TEN does not help that.
Will
Old Jan 4, 2002 | 05:35 AM
Mike K's Avatar
I have Mugen mounts in my Integra, and Prothane mounts in my Civic. No, not the Prothane inserts. The ENTIRE mount kit. You press out the meat in the stock front engine mount and insert this solid thing in there.
Can you say ******* VIBRATION? It's coo' because it's not my daily driver. The vibration can be soothing at times, also.
Old Jan 4, 2002 | 08:32 AM
houston's Avatar
Default Re: Wheel hop on acceleration. (Mike K)
this kinda leads to a question /problem
I got ES inserts in my car .. on my old car i just had the front ones in.. I could tell it vibrated a helluva lot more.
this one i have all 3 and there isnt really any vibration... strange chit..
I think something is wrong. dunno what yet..
I get hella chatter through the clutch so i cant tell if im hoppin.
Old Jan 4, 2002 | 08:39 AM
Jason's Avatar
http://www.summitracing.com has them for like 37bucks + 7 handling charge per order...if you need anything else, get them at that time and save...like shifter bushings too! ES mounts...that's where I got em...
Old Jan 4, 2002 | 11:56 AM
Batoutahell's Avatar
I still get wheel hop with the ES motor mount insert kit.
Old Jan 4, 2002 | 12:55 PM
B2FiNiTY's Avatar
Default Re: Wheel hop on acceleration. (Batoutahell)
Has it decreased it?
Old Jan 4, 2002 | 01:02 PM
Bbasso's Avatar
Where sould we get these motor mounts from? and how much time/ labor is it to install?
Old Jan 4, 2002 | 01:04 PM
AssPenny's Avatar
Default Re: Wheel hop on acceleration. (Bbasso)
http://store.summitracing.com/partdetail.asp?part=24947
Old Jan 4, 2002 | 01:12 PM
Bbasso's Avatar
Default Re: Wheel hop on acceleration. (AssPenny)
the ones from summit are the best or are there better?
Old Jan 4, 2002 | 01:17 PM
Willard's Avatar
If you have money to burn...
http://www.kingmotorsports.com/produ...uspension.html
Look under "Hard Bushings"
Will
Old Jan 4, 2002 | 01:29 PM
Default Re: Wheel hop on acceleration. (B2FiNiTY)
Yes wheel hop has decreased, but it isn't that hard to induce hop even with the inserts installed. AFter installing the rear insert a few weeks ago I was hoping to cure hop altogether, but no dice. All in all, it's a very good mod for the price, but it doesn't magically cure wheel hop in all cases.
Old Jan 4, 2002 | 04:59 PM
itr1275's Avatar
I would try the cheapest thing first, wheel balance. It could cause wheel hop and vibrations. Chances are, with that milage, your due for tires anyway.
Old Jan 5, 2002 | 03:54 AM
NunRacer's Avatar
Default Re: Wheel hop on acceleration. (itr1275)
Thanks for all the help.
I guess I'll try the motor mounts.
Old Jan 5, 2002 | 04:23 AM
SEFIxCivic's Avatar
The thing is poly engine mounts won't stop tire shake which is attributed to the bushing in your lower control arms, however, the z10 bars will. On older cars with really worn lower control arm bushings, they do something that feels like wheel hop under extremely hard braking. This is due to the lower control arms ocillating back and forth so intensely that it shakes the drive train thru the axles. Needless to say with the radius arms Geoff designed this nolonger happens. Just a heads up. For anyone who does a lot of drag racing, motor mounts + radius arms are the way to go.
Old Jan 5, 2002 | 04:30 AM
JDM_DOHC_SiR's Avatar
New User
POLY' is Your Friend..
AznBlueBoy
Nov 13, 2005 01:06 PM
elitesi8
Oct 9, 2005 06:42 AM
crx_of_fury
17
Jan 10, 2005 02:33 PM
bluedelsol
Feb 6, 2003 06:20 PM
IVANITR
Jul 9, 2002 03:16 PM
