what has more parts zc sohc or dohc
Old Dec 15, 2004 | 07:00 PM
Rainville's Avatar
Default what has more parts available zc sohc or dohc ???
bolt ons and internals, does the dohc have a usdm equivelant.
Old Dec 15, 2004 | 07:35 PM
90LSpimpin's Avatar
Default Re: what has more parts available zc sohc or dohc ??? (Rainville)
As far as I know, the sohc zc is equivalent to the D16a6, so those parts should be compatible. And the dohc is similar to the D16a1, so those parts should be interchangeable. Search more to confirm my thoughts.
Old Dec 15, 2004 | 08:00 PM
ServiceAdvisor's Avatar
Depends on how hard you look and how much $$$ is in your pockets. - Darrell
Old Dec 15, 2004 | 09:26 PM
silent-chris's Avatar
Default Re: (DOHCZCCRXSi)
i am pretty sure that everythng from the DOHC ZC motor is compatible from an 86-89 teg not 100% sure though
Old Dec 15, 2004 | 09:30 PM
90LSpimpin's Avatar
Default Re: (silent-chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silent-chris &raquo;</TD></TR><TR><TD CLASS="quote">i am pretty sure that everythng from the DOHC ZC motor is compatible from an 86-89 teg not 100% sure though </TD></TR></TABLE>
=D16a1
Old Dec 17, 2004 | 07:34 AM
Rainville's Avatar
Default Re: (89SiPimpin)
zc sohc = d16a6 - ?
zc dohc = d16a1 - 86-89 integra
Old Dec 17, 2004 | 08:03 AM
90LSpimpin's Avatar
Default Re: (Rainville)
sohc zc = d16a6 - 88-91 civic/crx SI
Old Dec 17, 2004 | 08:06 AM
90LSpimpin's Avatar
And with pretty much all of the sohc D series motors from 88-2000, there is a lot of compatability between motors.
I.E , they'll all bolt up to the same trans, headers and intake manifolds are swappable, different heads from the years will bolt up, random internals can be used between eachother, i couldnt tell u exactly which ones, but it works.
Old Dec 17, 2004 | 08:19 AM
Rainville's Avatar
thanx for the info, in the spring i'm going to do a zc dohc swap. I was trying to ask about the availability of parts for it (if the dohc had no parts i was going to go with the sohc). do you know the bhp of each zc.
Old Dec 17, 2004 | 08:31 AM
90LSpimpin's Avatar
Sohc ZC I believe is 120 with 103 torque
Dohc ZC - 130, with probably about 111 torque
Old Dec 17, 2004 | 09:59 AM
wompwomp61's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89SiPimpin &raquo;</TD></TR><TR><TD CLASS="quote">Sohc ZC I believe is 120 with 103 torque
Dohc ZC - 130, with probably about 111 torque</TD></TR></TABLE>
the only difference with the sohc zc and the d16a6 is the cam. i've heard stories of slightly different shaped pistons
Old Dec 17, 2004 | 10:16 AM
DJ_SaNdOz's Avatar
Default Re: (wompwomp61)
the parts for the a1 won't really work for the a8/a9/zc.
Old Dec 17, 2004 | 02:28 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: (DJ_SaNdOz)
i run the dohc zc but i prefer the sohc zc becuase theres way more parts available cause its a single cam. the dohc zc is the oddball of the d series, cause its got 2 cams, and pretty much no aftermarket compared to any other d series motor out there.
the king.
Sep 26, 2006 12:32 PM
ilovemyb16a
72
Apr 26, 2006 07:54 PM
crex23
18
Mar 30, 2005 05:03 AM
Dwight Schrute
Feb 22, 2004 03:01 PM
SHo X dragger
Feb 10, 2002 07:47 PM
