Vibration Issue (searched but no definite answer)
Old Dec 15, 2004 | 05:56 PM
97mini-me's Avatar
Default Vibration Issue (searched but no definite answer)
I have a 97 civic hatch with a jdm ITR swap. I have had vibration problems since I put the engine in the car. I think it has something to do with the axles. I had to replace one axle because the end splines were mushroomed from when they removed it from the donor car in japan. I got a 97 gsr axle and then later replaced the other axle with the same because of a leaking boot.
Now, my question is this....
Could my vibration be caused by using two US axles with a JDM intermediate shaft?
HELP ME PLEASE! I have searched, but no one clearly explains if this could be the problem. Explainations? Thanks alot!
-Brian
Old Dec 15, 2004 | 06:04 PM
PyroProblem's Avatar
Default Re: Vibration Issue (97mini-me)
I currently have this problem and it seems that a vibration while accelerating only is caused by BAD INNER CV JOINTS...
If its under any load at a more specific speed, its more than likely a wheel balance problem.
You probably got some old/bad axles...
I bought this set at Autozone and they are vibrating.
Old Dec 15, 2004 | 06:25 PM
97mini-me's Avatar
Also, I forgot to mention, the vibration only occurs under acceleration. It is fairly violent and if I am going up a hill or something it seems to get worse at low speeds while slightly accelerating. Enough to move the wheel about an inch or so.
Old Dec 15, 2004 | 06:29 PM
yeah its the inner CV joints. Mine vibrate under heavy acceleration also.
Id say get some good aftermarket or OEM ones to be 100% sure your getting good axles...
Autopart stores are usually remanufactured and can be bad too. The ones I have vibrate and theyre less than a year old from Autozone...
Old Dec 15, 2004 | 06:40 PM
SD1222's Avatar
Default Re: Vibration Issue (PyroProblem)
mine does the same thing too when your going at a lower speed. So i changed the axles bought it NEW from NAPA and the car still vibrate so i know for a fact that it can't be the cv joints. My guess is the wheel bearing. And that's where i'll be looking at next
Old Dec 15, 2004 | 07:16 PM
97mini-me's Avatar
My car was perfectly smooth before the swap though. It has to be one of the components that wasn't there before.
Old Dec 16, 2004 | 12:33 PM
97mini-me's Avatar
bump. Any ideas?
Old Dec 16, 2004 | 02:35 PM
Burke's Avatar
Banned
mine did that with a bad wheel beraing as well. have you checked you tie rods and ball joints?????????????????????//
Old Dec 16, 2004 | 06:42 PM
sk8rmike's Avatar
Default Re: Vibration Issue (Burke)
check the tie rod ends and wheel bearings. the JDM intermediate shaft is exactly the same as the USDM version. the issue you are describing i see quite often at work, it is very often inner tie rod ends or defective cv axles (much more frequent for the culprit to be a inner tie rod end).
jxhxb
Suspension & Brakes
18
May 21, 2014 06:59 AM
dadrought6
Oct 18, 2008 11:19 AM
CustomX113
Dec 20, 2006 10:21 AM
fred92htch
Jul 10, 2002 02:07 PM
Fooman
Jun 3, 2002 09:14 PM
