Where's the horn Relay??
Old Dec 15, 2004 | 12:28 PM
92HB_HB's Avatar
Default Where's the horn Relay??
Can anyone help me locate the horn relay on my integra ?? i'm looking to do some security upgrades to my car and want to locate it so i can add some wiring.. thanks..
Old Dec 15, 2004 | 12:42 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Where's the horn Relay?? (92HB_HB)
What do you need to get to the relay for? Use the trigger wire coming down the steering column.
Old Dec 15, 2004 | 12:43 PM
92HB_HB's Avatar
Default Re: Where's the horn Relay?? (JDM_Ej)
the trigger wire is tied into that dam SRS cable that is flat.. i dont want to mess w/ that if i can easily get access to the harness that goes to the horn relay..
Old Dec 15, 2004 | 07:28 PM
biotech0123's Avatar
I can definitely agree with that srs wiring **** cause I got to fooling around with it and tried to use one wire for the horn and screwed it all up. So I had to make a push button horn in order to have one for my curiosity.. But if you can get ahold of a schematic you should be able to find it under the dash right below the steering column
Old Dec 16, 2004 | 08:08 AM
92HB_HB's Avatar
Default Re: Where's the horn Relay?? (biotech0123)
how about somone take a pic of the under dash, and circle it.. just a though..
FOUND IT... thanks for looking, but not telling
Modified by 92HB_HB at 6:48 PM 12/16/2004
B_Swapped93
Feb 16, 2014 06:26 PM
mugen si
Aug 16, 2009 05:43 PM
Honda_Cribb_GS-R
Jan 13, 2009 08:58 AM
tei344
Nov 9, 2007 05:51 AM
JspecFerio
Nov 1, 2002 12:15 PM
