Hey i need a socket size
Old Dec 15, 2004 | 12:15 PM
honda17's Avatar
Default Hey i need a socket size
Ok i know tihs might be a dum question /but i need to know the socket size for a 89 honda civic ackles the nut right when u take the wheel off in the center of the brake roaders. what size is that?
Old Dec 15, 2004 | 12:25 PM
johnzm's Avatar
Default Re: Hey i need a socket size (honda17)
32mm and its TIGHT
Old Dec 15, 2004 | 12:27 PM
honda17's Avatar
Default Re: Hey i need a socket size (johnzm)
thanks man
Old Dec 15, 2004 | 02:34 PM
triple_s1x's Avatar
Yup, just get a long pipe and a breaker bar, show the nut whos boss
Old Dec 15, 2004 | 02:57 PM
HamiltonRex's Avatar
Default Re: Hey i need a socket size (triple_s1x)
make sure its 3/4" drive.
Old Dec 15, 2004 | 03:23 PM
Outsane's Avatar
Default Re: Hey i need a socket size (HamiltonRex)
if your ghetto 1 1/4" socket works also
Old Dec 15, 2004 | 03:31 PM
B2FiNiTY's Avatar
Default Re: Hey i need a socket size (Outsane)
Remember to unstake it first
Old Dec 18, 2004 | 09:50 PM
honda17's Avatar
dam i guees i am getto cause i used 1 and 1/4 lol
Old Dec 18, 2004 | 09:51 PM
honda17's Avatar
i did use a pipe lol it worked i showed the nut who was kin of thi jungle
Old Dec 19, 2004 | 04:06 AM
jay-tec's Avatar
hope you have air tools. a really good impact gun will zip it off like nothing. otherwise.... goodluck
Old Dec 19, 2004 | 08:15 AM
SiRex91's Avatar
Default Re: Hey i need a socket size (jay-tec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay-tec &raquo;</TD></TR><TR><TD CLASS="quote">hope you have air tools. a really good impact gun will zip it off like nothing. otherwise.... goodluck</TD></TR></TABLE>
A breaker bar with a cheater pipe will work. Just make sure you put another pipe in between two lug studs so it doesn't spin. Also, before you put a new captured nut on, put some anti-seize on the threads of the axle, so you won't have such a tough time getting it off again.
Everytime you remove the axle nut, you're SUPPOSED to replace it with a new one.
Old Dec 19, 2004 | 09:53 AM
eda6's Avatar
Default Re: Hey i need a socket size (SiRex91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRex91 &raquo;</TD></TR><TR><TD CLASS="quote">Also, before you put a new captured nut on, put some anti-seize on the threads of the axle, so you won't have such a tough time getting it off again.
Everytime you remove the axle nut, you're SUPPOSED to replace it with a new one.</TD></TR></TABLE>
i used wheel bearing grease instead of anti-seize. The axle nut is torqued to 134 ft.lbs. My axle nut comes off easily with a 1/2" drive 18" breaker bar.
Old Dec 19, 2004 | 05:23 PM
Rostr02's Avatar
Default Re: Hey i need a socket size (eda6)
i broke a breaker bar trying to remove one I was jumping on the damn thing for a good
thing the breaker bar was from sears.
to antiseize
Old Dec 19, 2004 | 07:17 PM
Burlyirishdude's Avatar
Default Re: Hey i need a socket size (Rostr02)
I had to take a torch to mine. I almost burnt the bearing. I broke two crafstman 2/4" drive 32mm with a lsudge and standing on it. I broke them and took them back...gotta love sears.....I took some acetelyne and some o2 and had to brun the ******* off. good luck.
Old Dec 19, 2004 | 07:36 PM
Custom Rex's Avatar
Default Re: Hey i need a socket size (Burlyirishdude)
i tried mine by hand, 2 sockets and couple rachets later, i just took the whole spindle into work , 1 lil zip from my air gun at work and it came off...
Moral of story:
Use Air gun if it doesn't come off by hand
Old Dec 19, 2004 | 07:45 PM
Recluse03's Avatar
make sure to use a punch to open it up and then go with a 1/2' inch breaker bar and 32 mm socket. best if done while its on the gound so that the axels do not rotate
}-Black-Ls-Stunna-{
Oct 26, 2008 12:11 PM
mtownek9
Feb 7, 2008 07:55 PM
Boriqua0555
Jun 30, 2007 01:16 PM
vtec.dc2
Nov 6, 2006 06:09 AM
timntam
Suspension & Brakes
18
Jan 26, 2005 06:00 PM
